Athlon4all
I was talking in the DDR400 vs PC1200 thread in GH, and I am very confused on a couple things in regards to nForce and 850e/32-bit RIMMs and I was wondering if anyone could fill me in.
1: What is nForce 420-D's memory controller?? Is it Dual Channel DDR like E7500? Is it simply nothing more than Interleaved Memory controller?? Or what???
2: In 32-bit RIMM's, both 16-bit channels from the 850e chipset are run to a single RIMM slot correct??? Whats the benefit??? Originally, I thought that the 32-bit RIMMs would have internally dual 16-bit channels that would double the RIMM's bandwidth (ie PC1066 would get 4.2GB/ps per each chipset channel), and they would eliminate the need for a dual channel 850 chipset, but that doesn't quite make sense, but there still are some unanswered questions that I have. Like really what is the benefit or difference with 32-bit RIMM's? Other than not neededing to install them in pairs, I don't see the benefit. The Chipset still needs to be a dual channel chipset correct??? 2 pairs of 16-bit traces still have to be run from the chipset to the ram correct???
3: What exactley does the term "Dual Channel" mean??? What is the difference between Dual Channels and say 2 interleaved memory controllers like what nForce may be?
Thanks guys for any info you can provide🙂
