interface I2C to PC to read output
kcthomas
335
i have an IC that has both an I2C and a SMBus output (16 bits). I would like to interface it to a PC to read and analyze the data. what is the best way to do this?
Mark R
16
Connect it to an microcontroller that has I2C and serial-ports and have the controller run translation software to transfer messages across the interface.
You can buy these ready programmed - check out the BL233
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
If you have the I/O available, just feed the TTL into a parallel port on the PC and read the bits directly & translate them as necessary in the PC software.
If you're a bit shy on I/O from the MCU, then drop in a mux chip.
There are some I2C interfaces for PCs as well. Check out Circuit Cellar ( http://www.circuitcellar.com ).
Good Luck
Scott
