Just bought this one used for my bro's system. Had trouble getting the card recognized correctly under win98, which we assumed to be a driver issue due to the old Jaton tnt2 m64. Upgraded OS to winXP. Unfortunately, the default drivers that XP used leave me with odd visual abnormalities. There are verticle lines that are flickery every 1.5 cm or so. It is impossible to use...No problem, I installed the latest detonators. No luck. On reboot, the PC goes blue screen on me and resets, disabling the drivers I just installed. I have several times gotten the reference drivers to funciton briefly, but they almost instantly crash. The verticle lines disappear during this brief time (~30 seconds), but there is still a bit of visual weirdness (ghosting?) I checked, and the card is running at 200/400 (factory default). What is the deal? Can anyone help me?
Celeron 400 (usually at 500, but at 400 now and for the XP install.)
128 Mb RAM
Abit BX6
Thanks Atechers,
James
128 Mb RAM
Abit BX6
Thanks Atechers,
James
