Hi.
I am stuck in the design process of a small program I am working on. Here is the scenario.
- user select an option in the menu
- main thread creates a dialog box w/ process bar
- dialog box's OnInitDialog() sends a message to main frame
- main frame redirects to view
- view creates a worker thread
- worker thread goes through a for loop // (i = 0, 1 < 10000; ++i);
- worker thread posts a message to main frame on every iteration
- main frame redirects message to view
- view calls a function in dialog box to update process bar
Okay. The design above works fine. Here is one drawback. Even though the worker thread does all the processing (for loop), the main thread is *inaccessible* as it calls the function in the dialog box to update the process bar.
I would like to redesign that part of the program so that even as the worker thread is processing the for loop and as *some thread* updates the process bar, the user can still navigate the program.
Do I need to create a worker thread to update the progress bar? Do I need a UI thread? The reason I kept the dialog box as part of main thread is because according to Prosise, it is best to keep UI related objects in main thread.
Thanks,
Kuphryn
Thanks,
Kuphryn
