Interesting info about power consumption for FAH/GPU boxes
BillClo
241
I thought you all would like to see this that I posted elsewhere. It's in 2 parts as things developed...
Part 1 FAH Folding, CPU Client:
I did a little experiment to see how much power could be saved on machines that are candidates for conversion to the GPU client.
The machine tested is an Athlon 64 2.0ghz, 256mb RAM. It's a marginal folder on most Gromacs units, and only does a little better on Ambers, so I gave consideration to swapping it's motherboard out for one that's PCI-E compatible and adding an used X1900XTX card.
Baseline info:
Folding a P2124 unit, 2.0ghz. 113w used.
Underclocked to 1.2ghz 101w used.
Underclocked to 1.0ghz 97w used.
Normally underclocking it to 1.0ghz would result in much longer frametimes, on the order of twice as long. But since the GPU client isn't so picky as to the speed of the processor supplying it...
Undervolting the processor: left at 1.0ghz, 200FSB x 5 multiplier. Stock volts is: 1.45v.
1.4v 91watts used
1.35v 90 watts used
1.3v 88 watts used
1.25v 86 watts used
1.2v 84 watts used
1.15v 82 watts used
1.1v 81 watts used.
I didn't take it below 1.1v due to dimishing rate of return.
So for a dedicated GPU machine, I went from 97 watts to 81 watts by undervolting. Savings of 16w. Really I went from 113 to 81, with no real change in utility for the GPU client most likely.
Part 2, GPU Client related
Final report on this system.
Here is some data, and I'll let those of you more skilled at data analysis have at it.
Using stock CPU voltage, frame time and power useage at various CPU speeds, GPU Client on an ATI X1900XTX (650core/775mem, ie, stock 3d speed).
2.0ghz 6:12/frame 207w power
1.8gz 6:16/frame 207w power
1.6ghz 6:18/frame 198w power
1.4ghz 6:22/frame 193w power
1.2ghz 6:26/frame 192w power
1.0ghz 6:32/frame 189w power
After graphing it all up, I found that the power useage curve dropped off sharply between 1.8ghz down to 1.4ghz, and then leveled off at 1.2ghz before dropping again at 1.0. I think 1.4ghz is the sweet spot here.
Data showing power consumtion versus increase in frame time:
1.8ghz 0% reduction power, +1.07% frame time
1.6ghz 4.3% reduction power, +1.6% frame time
1.4ghz 6.7% reduction power, +2.6% frame time
1.2ghz 7.2% reduction power, +3.76% frame time
1.0ghz 8.6% reduction power, +5.37% frame time
Next I tried undervolting the CPU. Speed selected is 1.4ghz. Stock CPU voltage is 1.45v. I ran Orthos with a simulated Gromacs work unit to avoid corrupting the GPU client work unit if there was a Early Unit End due to crashing. I know the data isn't strictly comparable, but it gives an idea of what kind of reduction to expect with undervolting.
CPU voltage power watts used
1.45 (stock) 118w
1.35v 108w
1.25v 103w
1.15v 99w
1.05v 95w
I left the CPU volts at 1.05v and started up the GPU client. No change in frame times, and it's been processing for an hour now with no noted instability. Total system power useage dropped to 166-168w (keeps fluctuating between the 2 readings). So I went from 207w to 168w (savings of 39w) with a modest reduction in production of 2.6% (766 Points per day to 747: 19ppd difference).
As a side note, before I did this round of testing, I purchased an Antec 430w high efficiency power supply and tested it with the system still set up for CPU Folding. Power useage dropped from 113w to 97w. This is from an older Antec power supply rated at about 70% efficiency to the claimed efficiency of around 83% with the new one). See here: http://www.silentpcreview.com/article684-page1.html
GLeeM
7,199
128
Thanks BillClo, for taking the time to do the research and posting it here :)
Many will find it interesting and helpful :thumbsup:
Coquito
8,559
Excellent observations. Thank you for putting in the time to calculate all this.
Bookmarked. :thumbsup::)
Assimilator1
24,180
528
Interesting info :)
Though if I were you I'd run Prime 95 for 24hrs to be sure that your CPU is truely stable.
Pitty F@H is the only DC project to have a GPU client atm.
A point of possible interest ,my XPM @2.5GHz running S@H or DPAD draws 180w.
It's got 1GB RAM,2xHDD & an X800XT (which btw dropped GPU idle system power draw by about 5w over my old Radeon 9700 Pro;)).
My 2nd rig ,a S754 Semp 3100@ 2.52GHz did draw ~120w before I fitted a peltier ,now it draws 165 or 190w!:Q (depending upon setting) ,I didn't realise how power hungry peltiers were! ,I might yet ditch it:p (btw it had 512MB RAM & a GF4 Ti when I last tested it).
CupCak3
1,318
nice work on the tests BillClo! I'll have to come back to these when I have a chance and see I can I put these #s to good use!
Thanks!
