know of fence
Intel never claimed that Broadwell or Skylake would bring huge improvements. Still, looking at the Reviews of i7-5775C, I was surprised to see the pundits almost unanimously recommend Devil's Canyon instead, because it was much more affordable, available and higher clocked. I for one was impressed of the 5775C eDRAM gaming prowess and low idle power.
After Skylake was released somewhere between the pages and pages of technobabble, the IPC talk, meaningless benchmarks, and neatly arranged oranges and apples one simple fact was lost: Power consumption and power efficiency didn't change at all.
Isn't at the end of the day Performance per Watt the ultimate CPU benchmark? Haven't we all, myself included always taken for granted that a new process will bring better efficiency? - Not the case with Intel's 14nm, it seems.
Only much later looking at curiously high OC voltages it became clear that (load) power consumption hasn't changed. The best/only point of comparison is the i7-4790K and the i7-6700K running at the same base clock when multi threaded.
The differences in DRAM, chipset, motherboard as well as from one CPU to the next can be significant. The Techreport also measured the energy to complete a particular movie as slightly smaller but effectively equal. The rest of these bar graphs don't really allow efficiency comparisons, since the CPU clock and voltage are the determining factors, and clocks vary between the CPUs.
Slightly lower energy to complete the task for Skylake may be indicative of improved IPC here, or it may be a consequence of Turbo behavior.
So Techreport made no effort to discuss Vcore or OC'ing. TweakTown(dot)com on the other hand have been doing clock-for-clock comparisons for a while by setting all CPUs to 4GHz. Let's just assume IPC is close to equal. TT's 14nm Broadwell review shows no efficiency improvement, their measuring of power only works reliably for CPUs with integrated Voltage Regulators (FIVR).
"Broadwell and Haswell both have an integrated voltage regulator and all CPU power comes from the 8-pin. However, Ivy Bridge has some of its power coming from the 24-pin as well for the other voltage rails other than CPU and iGP. "
This Graph shows at least what kind of variation we can expect, from the same process, yet differently binned CPUs. Almost 18 W between early Haswell and 4790K both running at 4GHz. Also shows Broadwell behind the 4790K. The opposite of increased efficiency from a die shrink.
From their Skylake testing...
Curiously TweakTown's reviews doesn't explain if and how the VRs on Skylake are supplied. But power is still only measured at the 8pin CPU connector. Does the 6700K get also power from the huge motherboard connector?
I don't know if i should trust their Skylake number for these reasons, it might be that they just got a crazy good Sample, stating "I only needed 1.35v to get 4.8GHz under AIDA64 for an hour, and my temperatures didn't go above 80C [...] My really good Sandy Bridge CPUs could overclock and grab a maximum validation of 5.2GHz at 1.5v, Skylake can do the same. For reference, my good Ivy Bridge and Haswell CPUs had a very hard time doing this." - Source
So anyway TT has nothing but good things to say about the Intel CPUs, even though their Broadwell wattage shows no efficiency improvement and their Skylake thing is clearly either a statistical aberration or doesn't account for all of the motherboard power. Anandtech regulars should be no strangers to heaving to read between the lines.
As of recently best power consumption testing is probably done by Tom's and their 4790K (78.9 W) to 6700K (100.4 W) torture testing has 14nm consuming 21 W more. However as often the case with students and testers the author doesn't trust his data and he is careful not to draw conclusions. It hasn't occurred to him, that the old assumptions about improved power every shrink don't apply. So he promises to retest those numbers if required. Their CPU wasn't that great either: reaching an unstable 4.9 GHz @ 1.41 V. - Source
Intel have said that leakage was reduced and that the 14nm process can actually handle higher voltages, something quite unprecedented. IMO it is a very important fact and a necessary perspective for everyone. I'm not saying that jet fuel can't melt steel beams, but maybe we all should take a look at Skylake voltages and power. Intel were careful to say that we wouldn't see a jump like with the introduction of 22nm and that 14nm is a refinement of their previous process. Will the process mature over time, will the Kaby-lake refresh just bring higher clocks?
Power consumption differences are more pronounced in 4 GHz desktops, but they are proportional and they have a bigger impact on battery powered devices. MY (edit: wrong) guess would be that there too, 14nm hasn't claimed higher base clocks at the the TDP targets of 15 W and 45 W. Although clearly there have been improvements to idle power and power management (edit: below 3.3 GHz there seem to be power consumption gains troughout). I'll have to look into that next.
