Hello,
I'm running Windows XP with default drivers at 1600x1200 with a refresh rate of 85hz. I know refresh rate, Windows sensitivity, and acceleration should be the only factors affecting mouse speed.
After joining a Counter-Strike game (this is when I first noticed and is not necessarily the cause), the sensitivity has become much faster than it was (still on the same levels in game and in Windows) both in game and in Windows. For example, even on the first notch of sensitivity, I can move the mouse around a bit -- if you try this, you probably won't be able to move it at all. I'd prefer not to move down a notch in Windows because I already had sensitivites set in the games I play. This post: http://forums.anandtech.com/messageview.cfm?catid=27&threadid=574450&FTVAR_MSGDBTABLE=arc has a similar problem. I've tried installing the Intellimouse drivers, which did nothing, so I uninstalled them. I've tried various refresh rates, which strangely don't seem to affect sensitivity (I'm using RefreshForce). I'm also using the mouse fix so I have no acceleration, and precision pointing is unchecked.
Any ideas or suggestions would be great.
Thanks.
Thanks.
