IntelliMouse Explorer replacement.
paul878
I have used the Microsoft IntelliMouse Explorer since it came out and love it.
My hand does not get tired or hurt after hours of use.
I am looking for a replacement that have an higher DPI.
Logitech mouses are out of the question, while I love their accuracy my hand cramps up and hurt after about 2 hours of usage.
I use the palm grip, the claw grip it too awake and uncomfortable for me.
Can someone recommend an replacement for the IntelliMouse base on their personal experiences please.
I went from an IntelliMouse Explorer to a Logitech G5 and I still love it. However, if they cause your hand to cramp up, I wouldn't recommend them. What do you principally need your mouse for?
Game and internet.
I have try more than one Logitech, they are just not for me.
Maybe a Razer DeathAdder. 3500DPI and probably the best sensor in any mouse currently. No prediction or acceleration issues. Not priced too bad at $50 either. It has a similar shape to the IME 1.1/3.0
DA is definitely a good shout, really similar ergonomically. I only switched back to an IME3.0 really because the DA doesn't work well with my Talent pad.
The Microsoft Habu mouse looks very interesting.
Is the DA the same size as the IME3?
Bestbuy don't seems to carry high end mouse and keyboard anymore, anyone know a store in NYC where I can go check things out.
The DA is smaller. My local BestBuy had both the IME3.0 and DA in stock. I would think that NYC would as well...
Have you tried checking Microcenter?
