Wireless LAN consists on two main components.
1. Access Point (A/P).
Access Point is the Main Transmitter/Receiver that mediate between your LAN, and main computer, to the rest of the Network. It is connected to the LAN's Hub/Switch. It usually supports an excess of 100 clients.
2 . Wireless Client Card.
Wireless Client Card is the LAN card that you should install on your network computers.
Most Client cards are PCMCIA, which work very well with Laptops. For Desktop, it is usually better to use USB Wireless Card. Most PCMCIA Wireless Cards with fixed antenna (stuck behind the PC) yield inferior results versus the Flexible Antenna on a USB card.
If you don't have an established Network, and you want o share Wirelessly Internet connection, you need to buy Wireless Cable/DSL Router instead of the A/P.
A typical Cable/DSL Wireless Router, is a Combo unit, it is comprised of one A/P, three RJ45 connection (for three stationary computers), and one WAN connection for Internet sharing.
Conventional Wisdom* claims that the combination Orinoco Gold (About $90) SMC Wireless Router (About $150) yield the best results.
This link:
ORiNOCO PC Card - Gold.
There are no real big differences between the entry level Routers.
As can be seen in this link:
Wireless Routers Compared
If you just want an Access point:
Access Points Compared
When it comes to Wireless your mileage may varied, there are too many environmental variables that are unique to each individual setting.
