- Oct 11, 2000
- 56,336
- 11
- 0
Hi Anandtechies
I currently have this configuration:
Intel VC820 + Onboard Sound
Samsung PC800 128MB RDRAM
Pentium (533EB?) 733Mhz
Hercules Prophet II 64 GTS
Adaptec 29160 SCSI Card
Netgear FA311 NIC
I am trying to find out the "true" speed of my processor. I bought it from a guy on eGay and is was supposed to be a 733EB OEM. However, after installing it and running BIOS (changed jumber) for the mobo, it said I have a 533EB Processor. I have run the processor at 733Mhz (assuming it was 733) for 3.5 months now. I am not sure if the BIOS is wrong or what? I have flashed it and it still says 533EB. I ran Sandra Benchmarks on it and it tested out to 733 specs. I pushed it up to 800 last night and it was fine. Again ran the benchmarks program and it tested to 800 benchmarks. I thought that was remarkable. Not sure what the 820 chipset has for dividing the PCI bus and AGP bus. If the PCI bus works the same way as it does for the BX chipset, that would mean my FSB is running at insanely high speed especially when I clock the CPU for 800 Mhz. I calculated it based on the BX calculations and came up with a 200Mhz FSB... I know the PCI and AGP bus cannot divide this enough to run at 33Mhz and 66Mhz respectively.
Can someone please tell me what the heck is going on with my computer? Is my BIOS wrong or something? 200Mhz FSB is crazy!!!
Any input would be appreciated, especially from those with a similar setup.
Thanks!!
Netgear FA311 NIC
Thanks!!
