- Jun 30, 2004
- 16,622
- 2,024
- 126
Somewhere buried in dated pages for this motherboard forum, there is a thread on ISRT -- a feature of the Z68 chipset.
It's my personal judgment that ISRT is "here to stay," and it will be implemented in future successors to Z68. Our assessments of how well it works, caveats and frustrations with making it work, are in that thread.
Even so, I believe I've stumbled on a bug or annoyance with ISRT [by which I mean the SSD-caching/HDD-acceleration].
When running ISRT while attempting to install large software packages from optical installation discs (like MS Office Pro), I've seen the SSD being "kicked off" during the installation, subsequent malfunctions in the software installations, sudden "disappearance" of the optical [DVD-RW] drive, or "hanging" of the installation program.
In each and every case, with each and every symptom, the problem disappears by attempting the install again after unhinging the SSD-caching. I had also discovered that you can "unhinge" the RAID configuration without deleting it and starting from scratch. This is particularly nice to know if you use some part of the SSD as a formatted partition unrelated to the HDD acceleration, so you won't lose your data in that partition.
It seems to be an acceptable or minor annoyance unless you're planning to install new software every day or every week.
