Intel Skylake complete lineup - Coming in August - Pictures of CPU
jpiniero
15,092
5,655
I'm actually kind of surprised they aren't skipping Broadwell for the desktop entirely with the Skylake launch being to close. But I guess they can get the desktop parts to system builders who were already using Broadwell compatible motherboards and now they can advertise them as having the newest generation Intel processor.
They wanted to get new desktop Iris Pro models out, both R and the new unlocked LGA C models. The Skylake version with 4+4e probally isn't ready yet.
erunion
765
Not necessarily. "95W" is a "standard" TDP class / category. Haswell and Ivy Bridge were initially "95W" too.
You're correct that ivy bridge had 95w placeholder TDP( meaning 95W class). But this looks like a final TDP, not merely a placeholder. We have the exact specs for each sku.
I'm confident it will be truly 95.
VirtualLarry
56,542
10,167
If that's true, and the final characterized TDP of SKL desktop K CPUs is 95W, then what does that mean for the 14nm process? Why has TDP gone UP, from Ivy to Haswell, now to SKL?
JDG1980
1,663
570
What it means is that the power curve of 14nm was optimized for low-power parts, and 14nm is less efficient at high frequencies. We really, really need new node processes optimized for high performance, but we aren't getting them.
The good part is that Intel's 14nm could potentially be beaten by TSMC's 16nm FinFET, which will have a dedicated high performance node. The same is true if Global Foundries makes a high performance dedicated version of Samsung 14nm FF. Intel may still have an advantage in mobile trash that they have to give away for free, but they're going to be facing hard competition from ARM in that arena. Try as they might, they've been unable to break into smartphones with anything but a handful of marketing demos.
erunion
765
I believe it would mean that Intel rated the TDP higher than required to cool the chip at stock clocks. Meaning they did it with over clocking in mind.
The other possibility is that the unlocked chips are operating at the upper limit of 14nms clocks. Requiring a massive TDP increase for a small clock bump, Similar to AMDs 220W CPUs.
VirtualLarry
56,542
10,167
I thought that the particular hit to the voltage / performance curve was said to be a "one time thing", upon the adoption of FinFET. Now, we're seeing it happen with every shrink?
erunion
765
That was a theory on this forum, but new evidence suggests 14nm doesn't clock as high as 22nm. Even at the same 65W tdp, Broadwell Iris Pro has a slightly lower turbo than Haswell Iris pro. Same is true for SKL vs DC.
Idontcare
21,110
59
We haven't "seen" anything yet. Everything being discussed here is just speculation on rumors.
Eh, no. The drive currents aren't even close to make that happen. You'll continue to see sub-3GHz (max) stuff from the foundries while Intel will still be pushing >4GHz stuff from their node.
imported_ats
422
63
86
On LGA 1366 validation time difference between Xeons and the consumer Bloomfield was only one quarter.
Examples:
i7-920 launched Q4 2008 --> http://ark.intel.com/products/37147/Intel-Core-i7-920-Processor-8M-Cache-2_66-GHz-4_80-GTs-Intel-QPI
Xeon X5550 launched Q1 2009--> http://ark.intel.com/products/37106/Intel-Xeon-Processor-X5550-8M-Cache-2_66-GHz-6_40-GTs-Intel-QPI
Those are the same die. Current HEDT is using a different die than mainstream DT.
Current Design breakdown is roughly:
Ultra Mobile
Mobile/Desktop
Server/HEDT
Old 920 era breakdown was:
Mobile
Desktop/1-2P Server
4P Server
When they went to fully integrated desktop parts (ie on board PCIe), HEDT/1-2P Server had to merge in with 4P Server functionality wise.
Fjodor2001
3,989
440
I guess you are referring to the low power mobile chips from the foundries, which aren't really comparable to high power Intel desktop CPUs.
The high power AMD desktop CPUs from the foundries are already at above 4 GHz.
TechyGeek
108
9
I suspect the same. Someone do a delta between Wattage and Frequency increase for top bins in each category of Skylake and Haswell please?
This suggests a poor overclocking chip. 4.2 turbo (single core?) vs 4.4.
Given that you can't regularly take Haswell and give it ~1ghz oc vs, Sandy having 1ghz oc regularly, I can't expect Skylake to have better OC than Haswell.
cbn
12,968
221
Ultra Mobile
Mobile/Desktop
Server/HEDT
Mobile
Desktop/1-2P Server
4P Server
Yes, the LGA 1366 Xeon and the LGA 1366 consumer quad core did use the same die. The mainstream LGA 1156 Lynnfield (that followed LGA 1366) had a even larger die due to the extra integration.
But now the reverse is true and the E5 Xeons/HEDT platform uses a much larger die than the mainstream.
The large difference in die sizes is the main reason why I think the E5 Xeon and HEDT are much delayed compared to the mainstream. (See post #38 ---> http://forums.anandtech.com/showpost.php?p=37351858&postcount=38)
TechyGeek
108
9
Wattage | Haswell Frequency | ΔW & Frequency Hw | Skylake Frequency | ΔW & Frequency Sk
95 - - - -- - 4.0 Ghz - - - - - - - 0.9 Ghz/23 watts - - - - 4.0 Ghz - - - - - - 0.6 Ghz/30 watts
65 - - - -- - 3.1 Ghz - - - - - - - 1.1 Ghz/30 watts - - - - 3.4 Ghz - - - - - - 0.6 Ghz/30 watts
35 - - - -- - 2.0 Ghz - - - - - - - 0 - - - - - - - - - - - - - - 2.8 Ghz - - - - - - - - - - 0
*Haswell 4790k uses 88 watts instead of 95 for skylake.
escrow4
3,339
122
Hee hee, will there be a 6771 that runs at 3.5Ghz to 4.1GHz? I clearly remember buying a 4770 non K base at 3.4GHz, and a 4771 for an extra $30 had an earth shattering base of 3.5GHz was also available. Guess which one I went for? Can't see anything here, have a 5930K in my gaming box. For SNB sure. IVB why not. Haswell eh.
SPBHM
5,058
410
similar TDP, clock, cores/threads... boring.
and no way to get our old DDR3s working with it?
AtenRa
14,003
3,361
The numbers of this graph is certainly NOT Cinebench R15 and certainly NOT ST.
It is Cinebench R11.5 MT.
ClockHound
1,111
219
Yes, looks like R11.5 MT numbers. And only 13% faster than DC. Kinda meh. If it overclocks better than DC, then it might be something of successor. If it overclocks worse, then there will be tears. Again.
If this a real benchmark, it seems Intel was smart to skip a Broadwell replacement for DC.
Oh, well, there's always 7nm to look forward to. In a short 3 to 6 years. Or so. Wake me up when we get there.
dangerman1337
333
IIRC Intel has varying 14nm nodes for low to higher power (besides TDP isn't a good metric for determing actual power consumption) while TSMC and Samsung only have one version for everything. I think its to show that the K parts have a higher threshold for overclocking which these parts seem to have.
SPBHM
5,058
410
Wow amd is that far behind huh? top end 5.0ghz barely even with i5 3.5ghz skylake.
Vishera is pretty old by now, from a company with very low R&D against Intel, and it's not looking to bad on those graphs, 8 core Xeon D with higher clock should be the new i7 920/2600K/3770K/4770K/4790K, not another 4C/8T CPU
oh wait, they can't do that, they have to use the die space from this enthusiast desktop CPU to build another huge laptop IGP with crappy performance, OK.
ShintaiDK
20,378
145
Remember Skylake will have a refresh too. So I am quite sure Intel isnt releasing the full potential from start.
ShintaiDK
20,378
145
The 4770/4771/4770K case was entirely different. So the most likely answer is no.
