"Intel Says Chip Speed Breakthrough Will Alter Cyberworld"
Wingznut
16,968
NY Times
Intel scientists say that they have made silicon chips that can switch light like electricity, blurring the line between computing and communications and presenting a vision of the digital future that will allow computers themselves to span cities or even the entire globe.
The invention demonstrates for the first time, Intel researchers said, that ultrahigh-speed fiberoptic equipment can be produced at personal computer industry prices. As the costs of communicating between computers and chips falls, the barrier to building fundamentally new kinds of computers not limited by physical distance should become a reality, experts said.
zzzz
5,498
Device physics: The optical age of silicon
GRAHAM T. REED
Graham T. Reed is in the Advanced Technology Institute, University of Surrey, Guildford, Surrey GU2 7XH, UK.
e-mail: g.reed@surrey.ac.uk
The silicon chip has been the mainstay of the electronics industry and it may similarly come to dominate photonics. A key component ? a high-frequency optical modulator ? has now been fabricated.
Research into optical circuits for communications began in the 1970s. Early visions of optical circuits were as 'optical superchips', containing light emitters, modulators, amplifiers, optical isolators, detectors and, latterly, electronic intelligence1. However, there are still differing views about the optimum material for such components. This is sometimes articulated in the phrase "optical circuits have yet to find their silicon" ? a reference to silicon's dominance in the microelectronics industry. Despite its success as an electronic material, silicon has received rather modest attention as an optical material. But that may be about to change. As they report on page 615 of this issue, Liu and colleagues2 of the Intel Corporation have now reached a milestone that bodes well for silicon's optical future: they have fabricated the first silicon-based optical modulator with a bandwidth that exceeds 1 gigahertz (GHz).
In technology terms, research into silicon as an optical material has been under way for a long time ? since the mid-1980s. However, relatively little progress has been made in comparison with more exotic materials such as III?V compounds (indium phosphide, gallium arsenide and related compounds), the insulator lithium niobate, or even silica (which typically uses silicon as a substrate material). That is not to say that little has been achieved, but the global technical effort has largely been concentrated on materials other than silicon.
There are two main reasons for this. First, silicon does not have an inherent mechanism for the emission of light: it is an indirect bandgap material, which means that its crystal structure makes it impossible to fabricate an efficient light-emitting device, such as a laser, from this material in the conventional way. The III?V compounds, in contrast, are direct bandgap materials and for this reason are often used in semiconductor lasers.
Second, silicon does not exhibit an electro-optic effect known as the Pockels effect, the traditional characteristic for fast modulation of light (that is, encoding data onto light by selectively changing its intensity). In other materials, such as lithium niobate, modulation is typically achieved via the Pockels effect, which causes a linear change in a material's refractive index with an applied electric field. Other optical modulators use electric-field effects known as electro-absorption and electro-refraction, but these are weak in silicon. Instead, modulation in silicon is achieved through thermal mechanisms, which are relatively slow (typically kilohertz), or through the introduction of free carriers (electrons or their positively charged counterparts, holes), which in turn results in both absorption and a change in refractive index. This latter mechanism, known as the free-carrier dispersion effect, is still also relatively slow, as it is associated with the physical movement of charge within the device. Nevertheless, it has been predicted that silicon-based modulators using this effect could achieve bandwidths exceeding 1 GHz (for example, ref. 3), although in practice working devices4, 5 have been limited to about 20 MHz.
Recently, however, there have been dramatic changes in the fortunes of silicon-based optoelectronics. Examples of progress towards a silicon light source are: doping with erbium6 to overcome the indirect bandgap in silicon; building small structures that enhance useful quantum-like effects7, 8; and novel approaches such as dislocation engineering9 and optical amplification through the Raman effect10, which could result in not only an optical amplifier but also eventually an optically pumped light source. Recently, the ST Microelectronics company has announced the imminent arrival of commercial devices based on silicon light-emitting devices.
If we add to this Liu and colleagues' announcement2 of an effective silicon modulator, the difficulties surrounding the optical performance of silicon seem to be being demolished one by one. Their device is based on the free-carrier dispersion effect and has many similarities to a CMOS transistor. It comprises a slab of 'n-type' crystalline silicon (n-type meaning that it is doped to have an excess of negative charge carriers, electrons), with an upper 'rib' of p-type polysilicon (crystallized amorphous silicon with excess positive charge carriers, or holes). A thin insulating oxide layer separates the p-type and n-type regions (Fig. 1 on page 616). When a positive voltage is applied to the polysilicon, charge carriers accumulate at the oxide interface, altering the refractive-index distribution in the device ? which will in turn induce a phase shift in an optical wave propagating through the device. This phase shift can be used to implement optical modulation. Furthermore, the response is fast: Liu et al. have demonstrated modulation frequencies in excess of 1 GHz with this device.
Of course, optical-system designers already require devices with bandwidths much greater than 1 GHz, but the demolition of this barrier by Liu et al. is significant: it is now easier to foresee the fabrication of even faster silicon-based modulators, although the technical challenge is still substantial. This could well signal the graduation of silicon from a subject primarily of academic research to a career as a viable photonic material with commercial applications. It is worth noting the affiliation of Liu and colleagues to the technology giant Intel ? if Intel and other semiconductor technology companies can develop silicon as successfully optically as they have electronically, then silicon is certainly set to grow in stature as an optical material.
Furthermore, consider the fabrication infrastructure that exists worldwide for silicon processing: the legacy of the microelectronics industry is enormous. Those working with microelectronic devices are now seeking to move beyond the critical dimension of 90 nm that is the state of the art. However, most optical devices made from silicon are likely to have critical dimensions of hundreds of nanometres for the foreseeable future, which means that the infrastructure already exists for the next several generations of optical circuits, if they are fabricated in silicon. This implies that the economies of scale that we have seen for the electronics industry could one day apply to the photonics industry.
The removal of the 1-GHz barrier and the imminent arrival of the silicon light-emitter are not the only reasons for this change in the fortunes of silicon photonics: for some years silicon has been seen as an ideal substrate material for optical circuits. Its well-studied properties are excellent for a 'silicon bench', an accurately machined silicon layer on which components can be positioned, aligned and attached to the outside world. Furthermore, for the networks of the future, it will be a relatively simple task to add electronic intelligence to a silicon optical device. This cannot be said for any other photonic platform.
At present the communications industry is experiencing its most serious economic downturn so far; the need for cost-effective technology solutions is underlined more strongly than ever before. Breakthrough developments such as this fast silicon modulator of Liu et al.2 suggest that a low-cost silicon optical superchip could soon be a reality.
So let us again consider whether "optical circuits have yet to find their silicon". It is already the world's favourite electronic material, and silicon could yet come to dominate the photonics industry as well.
References 1. Soref, R. A. Proc. IEEE 81, 1687?1706 (1993). | Article | ISI | ChemPort |
2. Liu, A. et al. Nature 427, 615?618 (2004). | Article |
3. Png, C. E., Reed, G. T., Atta, R. M. H., Ensell, G. J. & Evans, A. G. R. Proc. SPIE 4997, 190?197 (2003). | Article |
4. Tang, C. K. & Reed, G. T. Electron. Lett. 31, 451?452 (1995). | Article | ISI |
5. Dainesi, P. et al. IEEE Photon. Technol. Lett. 12, 660?662 (2000). | Article | ISI |
6. Franzò, G., Coffa, S., Priolo, F. & Spinella, C. J. Appl. Phys. 81, 2784?2793 (1997). | Article | ISI |
7. Canham, L. T. Appl. Phys. Lett. 57, 1046?1048 (1990). | Article | ISI | ChemPort |
8. Pavesi, L., Dal Negro, L., Mazzoleni, G., Franzò, G. & Priolo, F. Nature 408, 440?444 (2000). | Article | PubMed | ISI | ChemPort |
9. Ng, W. L. et al. Nature 410, 192?194 (2001). | Article | PubMed | ISI | ChemPort |
10. Claps, R., Dimitropoulos, D., Raghunanthan, V., Han, Y. & Jalali, B. Optics Express 11, 1731?1739 (2003). | ISI |
© 2004 Nature Publishing Group
Privacy Policy
zzzz
5,498
that was the news and views section of Nature, not the research article. I dont want to post the research article due to copyright issues..
Regs
16,666
21
Wow, even though I would have to take computer science and chemistry classes to fully understand what you just presented, very interesting in deed.
labrat25
557
now if we can store light (without close to absolute zero temps) we'll be set...
and then light computing will take off
GonzoDaGr8
2,183
Originally posted by: MercenaryForHire
In other news, Thomas Pabst was seen entering several Intel factories armed with Vaseline and kneepads.
:p
- M4H
D'oh.... :)
Good one M4H..:beer:
NFactor
153
BullsonParadise, they succeeded in stopping photons for a few microseconds a month or so ago at Harvard.
Dman877
2,707
From what I understand, the lack of optical amplifiers is holding up progress in this area.
Tom
"that will allow computers themselves to span cities or even the entire globe."
where will the cattle graze ?
sandorski
70,792
6,351
Great. In the future every juvenile who ever made a shadow puppet during class will soon be the hackers of the future! ;) :D
ST4RCUTTER
2,841
This is something that has been in the back of my mind for at least the last year. With the heat issues that are plaguing our current 90 and most likely 65nm processes this is something that will gain ground...I am thinking. The benefits of using photons instead of electrons is certainly there. I would be surprised if this technology is capable of supporting mass production until the end of this decade however.
grant2
1,165
23
Why would you want a computer to "span the entire globe"?? Just because light is foesn't mean you don't want compact circuitry to increase speed.
grant2
1,165
23
Ya not like electric computing, which hasn't taken off because we can't store electrons...
labrat25
557
yeah, but storing light as light has proved to be a bit more difficult
making non-volatile RAM is easy, making the light equivalent is a bit harder (and much more expensive/energy intensive)
Eug
24,160
1,806
Originally posted by: Budman
tell us what you really think Wingznut.
Yeah, sounds cool, but it seems like any practical implementation of this for us end users, if it ever comes to fruition, is a long ways off. What do you think Wingznut?
BFG10K
22,709
3,003
Sounds good and if it makes Doom3 and HalfLife 2 run faster I'll be happy. :)
