First they came for the PATA ports, and I said nothing.
Next they came for the PS/2 and LPT, and still I said nothing.
Eventually, they're going to remove the whole damn computer! 😛
I still use PS/2, LPT, and COM ports, along with my PATA and floppy, thank you very much.
This "legacy removal" bullshit has to stop, it's not "legacy" if people are still using it!
You still need a real floppy drive to install SATA/RAID/non-native PATA drivers under NT-based OSes.
You still need a PS/2 port for running my nice IBM clicky M13 trackpoint keyboards.
You still need PATA ports to run most existing CD/DVD reader/writers.
I still use a COM port for my external hardware modem, backup in case the DSL goes down.
I still use an LPT port for an external scanner too. I can also use it for a PSX-LPT interface, the LPT port is the lowest-latency interface on the PC.
Oh yeah, I have to "reset" (unplug) my USB peripherals, including my mouse, fairly often when that interface screws up and hangs. USB is NOT the wave of the future, it's more like a punishment. Cheap, ubiquitous, and crappy as all hell.
Considering how much modern "high-end" motherboards cost - the portion of that cost that "legacy interfaces" occupy, is far, far less than the profit margins on the chipsets used in the mobo. IOW, those extra PS/2 ports hardly cost anything additional to mfg. Most of the Super-IO chips are also the ones that do the hardware monitoring nowadays, afaik, so you wouldn't even be saving on the number of chips onboard.
