Intel(R) 82945G Express Chipset Family help
Dominato3r
5,109
i know integrated cards are fail and such, but i need some help until my 4670 arrives.
I just bought warhammer and the problem is that it checks your system before you can even enter the game. My card failed on vertex shader ( it has 0.0).
My question is...
Can you bypass this in anyway? is there software that can manipulate the client into think i have vertex shader 2.0
daveybrat
5,822
1,035
My question is...
Nope, you need to have that in order to render the games graphics properly. You'll just have to wait till your shiny new 4670 arrives :)
RadiclDreamer
8,622
40
Good luck playing any strategy games or games you need a KB for on a console. This is just one of the perils of playing fewer but usually better games
tcsenter
18,949
575
Make sure you have the latest GMA950 driver from Intel:
http://downloadcenter.intel.co...er.aspx?ProductID=2102
Intel Game Playability List
Warhammer 40000: Dawn of War Winter Assault* Expansion Pack game may display the following error: "No suitable display devices were found. Make sure that you have a video card that supports hardware T&L (Transform & Lighting)."
To work-around this issue, perform the following steps:
- Click Back on the Graphics Configuration screen.
- Select Safe Mode instead of Optimal.
The game should run properly in this mode. Intel is not aware of a fix for this issue. Contact the game manufacturer for further updates, patches, or support.
