Intel processors crashing Unreal engine games (and others)
Page 74 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Kocicak
1,071
1,130
You're still gambling at any voltage higher than 1.3v and any clockspeed higher than 5.3 GHz, which cripples Raptor Lake. You still aren't getting the performance advertised on the tin.
I just checked what limits I set for my new 13900KS and they are 5200/4200 MHz and 160W, I believe even the highest voltage spikes are below what you wrote. BTW I also got a 2x48GB RAM kit, which I bought for twice money I originally payed for my 2x16 GB kit, so that felt like a very good deal and it was totally wort it, I have more than enough RAM for at least 5 more years IMO.
There is nothing wrong with my PC now, Intel CPUs are just fine when you do not allow Intel to destroy them.
Markfw
May 16, 2002
26,129
15,274
well, that may be true. But now they perform way under what you paid for and AMD is much faster at everything now. (compared to yours)
alcoholbob
6,308
355
Seems pretty extreme considering the stock clocks of the 13900KS. Honestly I'm not aware of anyone on the various overclocking forums I've followed who had a degraded CPU who undervolted since Raptor Lake launched. This is a problem with the screwed up VID table Intel has since they don't have enough yields to meet demand for higher clocked i9s, and they don't have a very robust system of validating these chips so they just run them at much higher voltages then needed so they can get these chips out the door as fast as possible. AMD Zen 4 CPUs have much lower undervolting headroom than your average Raptor Lake CPU, which means they are binning and validating their chips much more efficiently than Intel from a business perspective.
You are better off just running stock all-core clocks and finding your lowest stable undervolt, taper your single core boost down to 5.8 (the regular 13900K speed), and likely it won't degrade any faster than any non-RPL CPU.
coercitiv
6,626
14,039
NTMBK
10,322
5,351
Despite having multiple posts in this thread, I just went ahead and bought a 14th gen i7 🙈
(The prebuilt I wanted only came with Intel options, and I just don't want to waste my weekends debugging a self build, I'm not 20 any more! I made sure there was a BIOS update with the Intel microcode fix before I hit buy though...)
Kocicak
1,071
1,130
Seems pretty extreme considering the stock clocks of the 13900KS. ...
Undervolting is a bad practise, see this post:
Kocicak
1,071
1,130
Isn't the microcode update just an undervolt?
No. They say is prevents overvolting. It does nothing to excessive frequencies. Intel cannot do anything with these, because they would face the need to compensate consumers for lower performance. So they just patched the CPUs somehow to make them last a bit longer without really solving the problem.
deasd
567
921
OK so this just unexpectedly turn into Intel RMA Lottery Festival.
PK1 on X claims to have discovered a loophole in Intel's RMA system — Intel didn't ask for proof of instability for the Raptor Lake RMA request. Thus, the Core i9-13900K owner requested an RMA on his perfectly functional Core i9 Raptor Lake CPU and received a full $599 refund for the chip, the full value of what the chip cost when it launched in 2022.
Another Intel customer, SomeOrdinary_Indian, posted the details of their Core i9-13900K RMA story to Reddit. The RMA was legitimate this time, as the CPU suffered instability issues. But in this instance, he won the "RMA lottery," receiving a more up-to-date Core i9-14900K from Intel instead of the previous-generation Core i9-13900K.
coercitiv
6,626
14,039
AFAIK microcode update tries to address overvolting, more exactly the high voltage requests the CPU makes when it expects transient fluctuations from increased loads. This is a compensation mechanism that goes above VID values and tries to make up for what the mobo power stage cannot supply "instantly". The compensation algo seemed to be... overcompensating.
As I understand it, this enables lower operating voltages, since it allows a lower guard band. (or higher clocks at max voltage, which ofc they did)
DAPUNISHER
29,562
24,423
The reps are overworked and harried; I am not at all surprised by the range of RMA experiences owners are having. It's completely FUBAR.
I'd return my 13900K too. It might be working fine now, but why risk FAFO if they will give me my $600 back after using it a couple of years?
alcoholbob
6,308
355
Interesting post. Reads alot like "don't exercise hard, because when you get older, your margin of safety for getting an injury is lower." I can definitely see where people get some weird learning heuristics from.
