- Mar 28, 2007
- 8
- 0
- 0
I've got two Intel Pro/1000 PT NICs installed in a machine running Windows Server 2003. I've got the latest version of the drivers (12.4 - 2/2008).
Here's the issue... When I go into the device properties, and use the Intel diagnostics, I get a result that the signal is good, but the cable is bad. However, I have another Pro/1000 PT installed on another machine running XP, and this one shows flying colors for both tests. I switched the cable to the server NICs, so we have the exact same cable, connected to the same port on the same switch - but the server NICs report poor cable quality. They are able to connect through these cables, but it concerns me that the tests show up with such poor results - and I have some other data transfer symptoms that might be explained by a high error count.
I find it hard to believe that both NICs (which are only a month old) are defective. So, perhaps there's something about Server 2003 that causes this? Perhaps it needs something tweaked in the driver settings?
Anyone familiar with these symptoms and can shed some light?
