Intel P4 & Matrox Parhelia Fan Replacement
TheBug
23
I want to replace the fan on my Matrox Parhelia with something quieter, but I want to make sure whatever I buy fits on the Parhelia and still performs within safety. Any suggestions?
I'm also looking into replacing the stock Intel P4 fan for my 2.4B GHz with something quieter. Does anyone know what the noise level of the stock fan is (so I can have some number for comparison when shopping for a new fan)? Also, I have a Asus P4PE. Is there any heatsink that will definitely not fit on it?
Thanks.
Fallen Kell
520
Don't know the stock numbers but a Thermalright STK-900 with a Panaflo 92mm fan will easily be quieter then whatever you got.
