Question intel onboard iv225 ethernet frequent disconnection issues
hardcore_gamer29
942
20
i just bought this new board asus z490f but the thing is having frequent disconnection issues. it drops then works fine. event viewer shows many e2fexpress issues as well
BoomerD
65,894
14,296
long standing problem with the intel i225 series. I have v.2 in my motherboard...same crap. Internet will be fine for days...or even a couple of months...then nothing. Rebooting almost always fixes it.
hardcore_gamer29
942
20
i boguht tplink pcie 4x card its realtek chipset left intel forever.... never going to buy asus board in future
Feb 25, 2011
16,991
1,620
FWIW, I've had two Ryzen boards with Realtek chips that did the same thing. Usually a disable/reenable of the onboard ethernet connection fixes it, but a reboot is less thinking.
tcsenter
18,891
543
Some resolutions that worked for some I remember reading last year...
  • try a different cable from reputable brand/vendor
  • try a different router
  • using latest Intel drivers from Intel (29.3.1) not from mobo manufacturer
  • disabling some Energy Efficient Ethernet, Green something power savings
  • check interwebs for latest NIC oprom/firmware
  • check for BIOS update for mobo
  • setting the link speed from "auto negotiate" to match your connection supported by the router. e.g. If router is 1Gb select that, if supports 2.5Gb then select that, not auto.
There is like a thousand threads about it on the interweb forums.
