- Mar 28, 2001
- 1,640
- 0
- 76
COMPONENTS: Intel E8400 Rev E0 (Stock Cooler), Asus Pk5 Pro (Latest BIOS), G-Skill 800MHZ DDR2 (5,5,5,15), PC Power & Cooling Silencer (750), PowerColor HD 4870, Creative Labs Audigy 2 ZS, Antec Nine Hundred, WD 640GB, and DVD Burner.
HISTORY: I am not an Overclocking Noob but I am an Intel Noob. I have been overclocking since the days of the P2 266 and the jumpers galore. Every system since then has been an AMD. My last system was a AMD Black 5000+ running at 3000MHZ.
STATUS: 3627MHZ! Yes, I have achieved a respectable overclock but I expect to get more out of it! I have not had to increase the voltage at all I just kept bumping up the FSB and ran a few loops of 3DMARK2006 in between and played some CSS for about 2 hours. I have been conducting business as usual for the last two days and it appears to be ROCK SOLID. I had jumped it up to 3800MHZ but the system locked up. I have placed a small fan on the Northbridge to keep it under 48c and I have a XIGMATEK|HDT-S1283 R on the way for the CPU.
QUESTIONS:
1.) I have set the Multiplier to 9 but CPU-Z is still reporting it to jump back to 6 once in awhile. I think this may have something to do with throttling (LAME). I know my mobo has some power saving feature so I am looking into that after I post this.
2.) What is the best plan of attack once I get my new HSF in, should I increase the voltage one step and start bumping up the FSB till it is unstable again and start the process over?
3.) Is it possible to make the memory speed fixed at 800mhz so that no matter how high the FSB is it won't run out of spec?
4.) What is a safe temperature for this CPU?
5.) Any other suggestions or gotchas I should know about?
Thank you in advance for any help you can render in my quest for 4000mhz on air.
Garrett
QUESTIONS:
Garrett
