Intel Newbie, Please Help - Mobo and System Recommendations for 1.6A
Fishmonger
173
Hello Everyone,
The last 8 systems that I have put together have all been AMDs, now I'm trying to help a friend build an Intel-based system. What I know for sure right now is that we are going to try to overclock it, but only using stock heatsink and fan for now (try to keep it quiet). Unfortunately, I don't know much about Intel chipsets and such, and I was wondering if you guys could be of assistance (it's greatly appreciated). After sifting through a bunch of forum posts, this is what I came up with:
1. Intel P4 1.6A Processor (seems like the best overclocker/best value)
2. Epox 4G4A+ Motherboard (seems like the best overclocking MB) Also considered Abit BG7. RAID is not really a needed feature. Would like to have onboard LAN and USB2.0. Are there any other suggestions for a solid overclocking MB under $150?
3. VisionTek Geforce3 Ti500 64MB
4. Samsung PC2700 256MB DDR Ram from Newegg (I heard this Ram used to be really good for O/C but not the latest batch? And how does this compare to Crucial PC2700 and maybe the cheaper stuff from Mushkin and Coasair?)
5. Evercase w/ 300W PS from Newegg (is 300W sufficient? I've heard lots of good things but this case being a great value)
6. Maxtor D740X Quiet 40Gig HD
7. Lite-on 16X DVD or Lite-on 40X Burner
8. Will be re-using his SB Live! soundcard and Floppy Drive
Is this a good setup to achieve a 2.4Ghz overclock on the 1.6A chip? I'm open to any suggestions/recommendations/changes, but the system has to stay around $700-$750 because that's my friend's budget.
Also, I have some cooling questions if anyone would like to help. I still have some ASII left over from my last AMD machine. Should I use that in place of the thermal pad that comes with the CPU? And if I was to shop for a better HS/fan, which one would be quiet and still gives better performance than the stock? My friend would like to keep this system quiet. And how many case fans do I need, if any? I'm considering maybe 2 Panaflows.
I know there are a lot of questions here, sorry I'm just a dumb newbie when it comes to Intel systems. Any help on any of these topics would be greatly appreciated. Thank you.
NikPreviousAcct
52,763
Check out my system specs here. I've got the Northwood running at 1.65V and doing a nice and stable 2.56GHz with all stock hardware.
nik
