Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 546 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
781
748
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Henry swagger
509
312
It appears the comparison actually isn't apples-to-apples cos LNC P core numbers include the massive L2 whether the Apple M3 numbers don't. Thats not right.
@DavidC1, @Hitman928, @AMDK11, @511 or any of you can please figure out the actual size of Lion Cove P core in LNL without L2? This would make the comparison more meaningful.
Edit: My bad. Got it from @DavidC1's post. Thank you!
So, now the numbers are in & both are on N3B & w/o L2:
Lion Cove P core is ~3.43 mm2
Apple M3 P core is ~2.49 mm2.
This makes Lion Cove a massive ~37% bigger but still less performant than M3! This is truly mind-numbing. Why is the P core so fat? Like some sort of fetish. Yikes. Somebody please fire the P core team asap!
Yeah intel p cores need a diet.. nearly 40% bigger than apple on the same node
FlameTail
4,384
2,761
It certainly makes for a hot discussion as to what caches should be included into "core area".
The thing is that Apple has only a 2-level cache hierarchy, whereas Intel has a 4-level cache hierarchy.
M3-P core
192 KB L1i / 128 KB L1d
16 MB sL2
Lion Cove (Lunar Lake)
48 KB L0d
2.5 MB L2
12 MB sL3
AMDK11
456
373
LionCove (LunarLake)
L1-I 64KB
L0-D 48KB
L1-D 192KB
L2 2.5MB
L3 3 MB/core (12MB 4 Core)
The Hardcard
320
405
Lion Cove is on N3B process, which affords at least 30% density advantage over N4, thus Zen 5 on N3B would end up being 3.2mm2, making Lion Cove almost 50% larger.
Yes, but it has much more cache. I am arguing that cache isn’t bloat. I think it’s valid to include the private cache in the core measurements, but it needs to be taken into account when assessing which design is more area efficient.
Bloat would be about the logic area, which is much closer than flat area calculations that include megabytes of cache others aren’t using.
Reactions: MoistOintment
SiliconFly
1,925
1,284
However we look at it, LNC is:
1. Fatter
2. Less performant
3. Less efficient
… compred to Apple M series P core. It’s just horrible. The P core team should hang themselves considering they’ve been doing this for many decades & Apple M silicon is less than 5 years old. Total messed up. Time to fire these idiots.
Your post offended pretty much everyone. Stating people should commit suicide is beyond distasteful, no matter how hyperbolic it was intended to be.
Mod DAPUNISHER
Reactions: Grazick
cannedlake240
247
138
1. Fatter
2. Less performant
3. Less efficient
Apples been dominating ST perf/W since 2012 starting with A7 soc. They're in a league of their own
poke01
3,754
5,089
1. Fatter
2. Less performant
3. Less efficient
That’s a bit harsh, it’s almost never the engineers fault but upper management who fail to see the future.
Reactions: FlameTail
AcrosTinus
206
209
1. Fatter
2. Less performant
3. Less efficient
You lost me there, we don't know the requirements to get high IPC on a x86 ISA vs ARMv9. I lack the education to even make a guess, hence I leave it to the PhDs.
The only thing I know, is that these are the most complex instruments humans can build and that improvements don't come by easy.
511
2,901
2,907
1. Fatter
2. Less performant
3. Less efficient
They could have had the lead except BK messed it up and their 10nm debacle also Apple has something that x86 lacks Flexibility to mold the ISA remove/add feature and build SW around it x86 is the most complex ISA in terms of Licence and design as well.
The Hardcard
320
405
1. Fatter
2. Less performant
3. Less efficient
I agree that Lion Cove is fatter and less efficient.
1 Apple Silicon is more than 5 years old. What is now referred to as Apple’s P core launched in 2013 in the A7. So the design began in the 2007-2008 timeframe.
Also, Apple has employed CPU and GPU architects since the 1980s. They have built extensive models of what they want from transistors. The Altivec extension of the PowerPC G4 was done by Apple CPU architects. So it’s not like they came into the room even in 2007 saying, “So, what do we do?”
2. Gerard Williams III designs are top notch, but his teams have freedoms x86 designers don’t have. They aren’t accountable to customers running software written in the 1980s and 1990s. Apple’s design team is the freeest, they can toss features the company pushed as the new direction developers had to adopt less than a decade earlier.
Reactions: 511
adroc_thurston
6,038
8,526
That's cause Y chips weren't excelling in any areas
Well the original Ivys, no, but things like Broadwell-Y were class-leading for their era.
The Y chips were super slow in both single thread and iGPUs
Frankly, any fat iGP in 10W premium tablet niche is kinda an excess.
The BOM argument is short-sighted.
It's literally the argument that sinks WoA every time. It's also the argument that makes LNL niche.
If you can deliver 85% of that battery life at 20-30% lower cost? hell yeah sign me tf up.
Reactions: Tlh97 and mmaenpaa
Hitman928
6,642
12,245
You are also missing the point, or maybe you aren't paying attention. Likely AMD has incorrect sensors as two outlets point this out, how the system power is comparable to Intel platform that has the TDP of the SoC set 5W or so higher.
You have a handheld, you are gaming. One has a 22W SoC but 30W system power, for 2 hours of gaming with a 60WHr battery. The other has a 15W SoC but still same 30W system power, for the same 2 hours of gaming with a 60WHr battery.
If Geekerwan or other outlets set the TDP to be same between Intel platforms and AMD platforms, the system power would end up being LESS than the AMD system thus you end up with better battery life.
As a user do you really care about SoC power? Especially when the system power numbers show different than expected?
Apple has way more L1 caches than both vendors. It's the fastest cache so it performs better, and it's the closest so you save power because you are needing to move less.
Other outlets I’ve seen haven’t shown this large discrepancy between sensors and power draw. For instance, when in as close to an identical laptop as possible, STX and MTL systems pull nearly identical wall power when both are set to 28 W limits.
An even more direct measurement of the cables on desktop systems show that the sensors are spot on once factoring in the VRM efficiency. Certainly no less accurate than Intel’s.
I’d need to see much more proof of this AMD sensors are bad theory as we have clear evidence to the contrary. Using different laptops, even with the display off, has too many variables to try and use it to test SoC power/performance at the system level. It’s a silly test. System level power/performance, sure, but it’s going to be individual to the laptop tested.
Edit: Another example in the opposite direction of why drawing SoC conclusions on system power draw is silly,
Asterox
1,042
1,837
Plenty of 285K runs
Seem comparable to 9950X's scores
Hm GB singlecore for K variant, it is significantly lower even compared to the R7 9700X.This is comparison with non K version. Multi-Core hm, as if the Intel CPU is broken or drunk. :mask:
Intel Core Ultra 9 285 non-K variant in GB, supposedly it's a 65W TDP version or a test.
AMDK11
456
373
Up
It was tested with a single 8GB RAM module.
LionCove:
C&C
Test Comment Lion Cove IPC Redwood Cove IPC Zen 5 IPC
XOR r,r Commonly used to zero registers. The exclusive-or of two identical values is always zero 7.31 5.7 5.01
XOR xmm, xmm Same as above but for a vector/FP register 7.31 5.71 4.99
Dependent MOV r,r >1 indicates move elimination 7.02 5.56 6.65
Independent MOV r,r Easy 7.25 5.71 5.01
Dependent increment Actual math, normally would create a dependency chain limiting the test to 1 IPC 5.6 5.53 1
Dependent add immediate As above but adding small numbers up to 20 instead of just 1. 4.36 5.47 1
Category Lion Cove Available Scheduler Entries Zen 5 Available Scheduler Entries
Scalar Integer Math 97 88
Floating Point/Vector Math 114 76
Memory Accesses 62 58
Structure Required if an instruction… Lion Cove Redwood Cove Zen 5
Reorder Buffer (ROB) Exists 576 512 448
Integer Register File Writes to a scalar integer register ~290 280 240
Floating Point/Vector Register File Writes to a floating point/vector register ~406 332 384
Mask Register File Writes to an AVX-512 mask register
Intel CPUs alias MMX/x87 registers to the same physical register file ~166 ~158 ~146
Load Queue Reads from Memory ~189 192 N/A, ~202 measured
Store Queue Writes to Memory 120 114 104
Branch Order Buffer Affects control flow 180 128 96
Reactions: SiliconFly
Nothingness
3,292
2,360
Integer performance of Lion Cove seems really strong.
After watching Geekerwan'a review, I am overall very impressed by Lunar Lake. It even beats the X Elite!
SPEC2017 INT
Battery Life test
It would be interesting to report SPEC results on battery, and how many times SPEC can be run on a single charge. That'd be unrealistic for many users, but at least we'd get a hint at how fast these machines are doing hard work unplugged (of course 1T might not be pushing them hard enough, but that'd be a first step).
Hulk
3,660
Point #2 has always amazed me. Apple has had what 3 total OS changes? Motorola to Power PC to x86 to whatever what they are on today is called. That's astounding and a big part of the reason they can do it is because they totally control both hardware and software.
This is the reason the PC and Apple can and will continue to coexist. They both serve different markets within the giant computer "tent." Some people, like me, want more control over the PC both from a software and hardware point of view. I want to build exactly what i want, I want to be able to run software I might have from 30 years ago (Quickbooks for example).
Others don't care what is going on in there. They just want to buy it all ready to go and know it works for what they need it for today.
Neither path is a better or worse, just different. Apple has done and continues to do incredible things with technology. The PC world just kind of plods along, generally putting one foot in front of the other.
H433x0n
1,224
1,606
Is ARL-S desktop gonna run hotter than RPL-S? Raptor itself runs real hot while gaming. What kinda of Arrow Lake temperatures are we talking about?
It doesn’t run hot while gaming assuming you’re using competent cooling. Look at cooler reviews from hardware canucks or similar YouTube channels and their results will be in the 50-80* C range.
Doug S
3,298
5,737
That's not true, at least not based on the Lunar Lake numbers FlameTail listed a few posts earlier - are those not correct?
