Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 543 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
696
602
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E08 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Abwx
11,557
4,349
So what? He's measuring motherboard power, so either AMD's system is a) wasting more system power thus can't allocated much to SoC or b) their sensors are bonked and it's using close to 20W rather than 15W.
You dont get it, it s due to the 258V boost being activated when set at 15W up to 22W while the 370 wont exceed 15W if set at 15W, Asus S16 use 6W on the main when idle and with a 16 OLED, so theories of 30W plateform power when the chip is at 15W is just plain ignorance.
Reactions: Joe NYC
Magio
88
85
51
You can see on the AMD's side, Steam Deck is most efficient with system capped at 15W, so Valve made a good choice.
Yep, the Deck is clearly held back by its aging architecture and process node, but you can clearly see it was built for performance at 15W (and even less) unlike AMD's chips since which fall apart at that kind of power draw despite their superior nodes and archs.
9949asd
127
82
61
Fans, fanboys, it's all the same i.e. not permitted. Attack the post not the poster. Please read and follow the CPU forum rules.
They go nowhere, this review is just dubbious, if the 370 plateform would need 30W to feed the Soc with 12W then the 370 coudnt score17k at 30W in R23 while the 288V is stuck at 10k at this same power.
The fanboy is the one who is shawn 22W in a screen and is still claming that it s 15W,
Look better your own screenshots, 10% higher fps at 50% more power :
Oh the you wants to compare multicore performance now? Tell me, a 4+4 8c8t compare to 4+8 12c24t, and you proud of it?
DavidC1
939
1,470
Deck also uses AMD, but that aside I know what you mean.
Oh the fanboy wants to compare multicore performance now? Tell me, a 4+4 8c8t compare to 4+8 12c24t, and you proud of it?
I would suggest that you would be careful using that word, otherwise I know a ban hammer might be coming, or at least a warning. I have my own opinions regarding AT mods, but just telling you.
Reactions: H433x0n
Magio
88
85
51
I know I was pointing out that the newer AMD designs aren't as well optimized for low power performance as the Deck. It's not even just 15W, Deck can even be made to deliver adequate performance (for less intensive games) at 10W or lower. All that was clearly not a priority for AMD when making Z1 Extreme or Strix Point.
Off topic but I hope Z2 Extreme will be better than Strix at low power, and especially hope that Deck 2 gets a custom chip with input from Valve again.
DavidC1
939
1,470
I have a feeling AMD is chasing Intel for high clock speeds and paying the price for it. It means the modern AMD chips are prioritized for higher clocks and sacrifice low clock efficiency.
Reactions: SiliconFly
AMDK11
426
338
desktop x86 CPUs absolutely. You see the reason why the M chips have such high ST is because Apple wanted to make an all purpose core that can used in mobile and desktop without sacrificing ST for mobile. If you go with that foundation for building chips you get the M series.
This is IPC, i.e. comparison at the same clock speed.
The x86 design cores from Intel and AMD provide high clock speeds, which on the one hand simplifies the design, but also makes the core logic less dense than it could be. High clock speeds mean many compromises in the core microarchitecture.
Apple designs cores for much lower clock speeds, so it can have a pipeline with fewer stages, lower cache latencies, and greater capacity. Apple cores are the power of huge amounts of resources: L1-I 192KB, L1-D 128KB, 10-Wide decoding, ROB 900+ 8xALU and very low latency.
That's it in a nutshell and simplified way.
H433x0n
1,209
1,572
This isn't "rigging" the results. The Phawx has noted something similar as mentioned here. I've queued it up to begin where he talks about it at ~17:10 in the video. The power reporting is less accurate on the AMD system, he typically compares an AMD CPU at 15W to an Intel CPU at ~20W and finds that they both will pull similar power. This would suggest that a LNL system that shows 22W (remember 2W for the memory modules) would be equivalent to the total package power draw as an AMD chip at 15W.
I know you're going to totally dismiss this but figured it's worth mentioning anyway.
DavidC1
939
1,470
And Intel/AMD needs to follow that direction, because I suspect large L1 caches are also contributing to efficiency in their designs because it keeps lot of data from going out into slower, higher power cache levels and memory.
The basis of Apple's design is also having stellar design team, because being able to have 4GHz clocks at such low power at just 9 pipeline stages and humongous L1 cache with 3 cycle latency is amazing. The E core team can still do quite a bit better, which is catch up with Apple's. It is even more impressive when you consider Mx chips have been stagnating for a while with smart engineers all into "AIeeee" hype and moving to startups.
Reactions: Tlh97 and AMDK11
DavidC1
939
1,470
This isn't "rigging" the results. The Phawx has noted something similar as mentioned here. I've queued it up to begin where he talks about it at ~17:10 in the video. The power reporting is less accurate on the AMD system, he typically compares an AMD SoC at 15W TDP to an Intel CPU at ~20W and finds that they both will pull similar power. This would suggest that a LNL system that shows 22W (remember 2W for the memory modules) would be equivalent to the total package power draw as an AMD chip at 15W.
This was also apparent for AMD's GPUs(at least the Polaris generation I don't know how the newer generations behave), where "board power" meant without the GDDR memory and the competitor Nvidia could accurately measure real board power.
poke01
2,205
2,802
Qualcomm follows the same cache hierarchy as M series and it fails in efficiency. Core architecture matters too I guess
adroc_thurston
3,572
5,155
but those fancy PMICs, MoP and generally high level of integration is translating into real world power differences.
Obviously but the price ain't nice.
LNL makes a lot of sense for premium low power thin and light.
It's a one-off and for a good reason.
Everyone is chasing clocks. You're like a year away from aa64 parts getting close to or breaching 5G mark.
and physical implementation
DavidC1
939
1,470
Of course. And there are matters which are impossible to see from a high level. You could give two design teams exactly the same requirements, heck even the same base uarch and one will simply end up being better than the other.
Some people are just better at some things than others.
9949asd
127
82
61
Well, some one is blind for the test results. This is not the first time in the thread. Just few days ago, the same thing showing 370 using 60+w and lunar lake using 40w. But fanboys keep claiming the soc power are the same on 28w🤣
AMDK11
426
338
Core architecture is the key that matters most (IPC). Intel claims that future generations will no longer focus on high clock speeds, but on IPC. It will be interesting to see where this goes.
Reactions: Henry swagger
DavidC1
939
1,470
By the way, it isn't entirely accurate to quote 2W. I bet this is maximum, similar to TDP numbers. Unless you run some sort of a memory power virus, you'll be hard pressed to even use 1W.
I can tell you on my Kabylake-Y Yoga that 1W is very rarely often reached. This is even more true on Lunarlake where the memory controller and the PHY itself is optimized for even lower power and has MLC to reduce access further.
Intel is clearly aware of this, thus for the most part the "2W" number is used to give more power budget for the rest of the SoC such as the CPU and GPU.
Reactions: lightmanek
Abwx
11,557
4,349
That s wrong, for the S16 Computerbase measured 28W in CB in HVinfo and NBC measured a little more than 30W for CB at the main, so AMD s telemetry is very accurate and it so for many years, beside you re talking of the Z1ex, dunno what it has to do with the 370.
All numbers for 288V and 370 can be found here :
DavidC1
939
1,470
Therefore history doesn't repeat but rhymes. It is mini Netburst to Core all over again. Raptorlake degradation is Pentium III 1.13GHz but 23 years later. The motivation is quite similar. Both pushed clocks too high to better go against competition, which in both cases is AMD.
KompuKare
1,191
1,487
Transistor counts don't really matter because they give wildly differing ones. Performance, performance per watt, peak clocks, performance at certain area, those matter.
Of course some armchair cost calculations would be interesting too but there are far too many hidden things.
It used to be that Intel's costs were pretty opaque but while they too are now on TSMC their new CPUs do use fancy new packaging technology (which I maintain is Intel's best investment in years) so even if we could estimate yields and guess TSMC's wafer costs - well we have no way to guess how much packaging costs are.
Costs only one factor. As Apple demonstrate if a costly SOC can command a high price due to great performance and perf/watt whereas a slightly cheaper SOC may not, then going cheap may be false economy.
Not expecting any price war, but I would still like to know who could afford to start one; I suspect Intel's production costs are higher and while their volumes make their fixed costs less of a factor it makes little sense for them start any price war. The other x86 vendor is no longer a budget brand so doubt they'd start anything.
Then again I may just love the idea of taking the area, going a yield calculator and a bit of playing with a spreadsheet later come up with some guesses
DavidC1
939
1,470
Silicon is called 21st century Goldmine for a reason.
The basic materials are really cheap. It's more expensive now(mostly because of processing such as EUV and R&D) hence why computer prices are rising, when it has been falling drastically. I remember Dell PC ads featuring $7000 desktops for the average consumer. Or how Pentium 4 was $1499 cdn.
The dual core Sandy Bridge generation for example was about 100mm2 and those were sold as cheap and readily as stamps would. It's like $5 for die and $5 for packaging, which makes die size vs price arguments silly. And they would turn it around and sell the top parts for $150(the amount Intel makes, not MSRP) or more. Or how 600mm2 server chips cost maybe $150 to make and is sold for many thousands of dollars.
