Page 537 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
Imho, I think what he's trying to say is that LNC didn't bring any great new ideas. Mostly minor upgrades rather than sweeping changes.
For comparison, Zen 5 didn't bring in any major performance uplift this gen, but the excellent ground work they've laid should help them immensely moving forward.
Intel has been spending way too much time and energy porting their existing designs to newer tool and design methodologies. But now they're on solid foundation and should be able to slice and dice easily to bring in sweeping changes next gen onwards.
He clearly wrote that LionCove is not contributing anything new, just like GoldenCove was not contributing anything to SunnyCove etc. And that is a lie.
The OoO engine in LionCove has been radically redesigned with future generations in mind, as has modular decoding in Zen 5.
These are fundamental changes for Intel and AMD that, to the average user who has no idea, will be nothing more than an evolution in the final performance of the LionCove and Zen5 generations.
"Unlike AMD Zen 5’s clustered decoder, all eight decode slots on Lion Cove can serve a single thread. Lion Cove can therefore sustain eight instructions per cycle as long as code fits within the 64 KB instruction cache."
Test Comment Lion Cove IPC Redwood Cove IPC Zen 5 IPC
XOR r,r Commonly used to zero registers. The exclusive-or of two identical values is always zero 7.31 5.7 5.01
XOR xmm, xmm Same as above but for a vector/FP register 7.31 5.71 4.99
Dependent MOV r,r >1 indicates move elimination 7.02 5.56 6.65
Independent MOV r,r Easy 7.25 5.71 5.01
Dependent increment Actual math, normally would create a dependency chain limiting the test to 1 IPC 5.6 5.53 1
Dependent add immediate As above but adding small numbers up to 20 instead of just 1 4.36 5.47 1
"Core Summary
All those caches help feed Lion Cove’s core, which has huge upgrades over Redwood Cove. The pipeline is wider, structures are larger, and a reorganized out-of-order engine helps Intel achieve higher scheduling capacity.
Much like Redwood Cove, Lion Cove is a wide and high clocked out-of-order design. But it’s easily the biggest change to Intel’s performance oriented architecture since Golden Cove. After Redwood Cove’s minor changes over Raptor Cove, and Raptor Cove barely doing anything over Golden Cove, it’s great to see Lion Cove’s sweeping changes.
Intel must have put a lot of effort into Lion Cove’s design. Compared to Redwood Cove, Lion Cove posts 23.2% and 15.8% gains in SPEC CPU2017’s integer and floating point suites, respectively. Against AMD’s Strix Point, single threaded performance in SPEC is well within margin of error. It’s an notable achievement for Intel’s newest P-Core architecture because Lunar Lake feeds its P-Cores with less L3 cache than either Meteor Lake or Strix Point. A desktop CPU like the Ryzen 9 7950X3D only stays 12% and 10.8% ahead in the integer and floating point suites respectively. Getting that close to a desktop core, even a last generation one, is also a good showing."
"Final Words
P-Cores have been Intel’s bread and butter long before the company started calling them P-Cores. Progress with Intel’s performance oriented cores hasn’t always been fast. Redwood Cove was only a slight tweak over Golden Cove. Skylake filled out five generations of Intel designs the same architecture. Going back further, Intel used the P6 architecture on the Pentium Pro, Pentium II, and Pentium III with just minor tweaks and clock speed increases in between.
Lion Cove is a much improved architecture compared to Redwood Cove, and shows Intel still has potent engineering muscle despite recent setbacks. Traditionally Intel delivered significant architecture changes during a “tock” in a tick-tock cycle. That reduces risk by separately handling process node and architecture changes. Lunar Lake not only combines a new architecture with a move to a new node, but also drops system level changes on top. At a time when Intel’s facing increased pressure from all sides, a move like Lunar Lake is a sign that Intel can adapt and survive.
Intel’s upcoming Arrow Lake desktop CPU will let Lion Cove stretch its legs with more cache and a larger power budget. Lower latency DDR5 should improve performance even further. After seeing Lion Cove perform well in a mobile form factor, I’m optimistic about what the same architecture can do on desktop. Recently Intel has been sitting on a rather unstable foundation with Raptor Lake, and Arrow Lake’s release will be a great time to put the company’s high performance chips back on stable footing."
It depends on what uplift you’re referring to.
For productivity Zen 5 does bring a solid improvement; not outstanding but still 15% isn’t a disappointment. And that will be roughly equal to what Intel will have done over the past 2 years (and they will have a slight node advantage). We’ll see soon as to whether Intels’ ST advantage will get eaten into compared to 13th-14th gen/Zen4. I think that will. With MT it’s a little less clear, but my guess is AMD will gain a bit.
For gaming, yeah it’s been a pretty disappointing, especially when considering the previous 2 generations. And their marketing clearly didn’t help the situation, plus the firmware updates.
But bottom line for me is: I think this year each product will be competitive. And that’s a good thing.
Almost every program today is multithreaded. Every program scale to as many threads as far programmers ability goes - limited by Amdahl's law. So when making benchmark that tries to simulate that result is something like GB6. Single thread speed ain't most important today, most commonly used workloads scale to multiple threads but not infinite threads. GB6 MT result reflects also gaming performance much better than something with unlimited scaling like CB or spec nt.
Are we forgetting old programs ? Cause many people use older stuff and not everything is MT
Single Thread is important as well even Today
What GB6 fails to show is to make badly performing cpu with many cores to have good result. That seems to be a great problem for many.
You mean good cpu shown with bad performance?
Single thread is important - but not by alone. Purely single threaded jobs are those old or so light that they perform well anyway on modern cpus. For heavier jobs programmer surely has tried to multithread program as good as they could. There performance is still mostly single-thread speed driven but cpus different hardware implementation leads to diffferent MT scaling. Most important benchmark is to measure that MT scaling. GB6 tries to do that - it's not perfect but pretty much best available.
The E core team had a clean slate. The P core team has just found their footing. They should be able to follow suit from now on.
The E cores didn't need a clean slate, because they are basically turning over tables every generation or two, which the P core team in their best days only managed to do when forced to such as with Netburst vs Core.
In Gracemont they entirely removed the L2 predecode cache that existed since Goldmont Plus, with a replacement called OD-ILD, which is a much more area efficient and permanent solution over ever increasing the size of the cache, which won't target large workloads. They did all that while delivering 30% per clock gains.
The thing is, it was a risk that performance could be lost significantly because one of the reason for eliminating the L2 predecode is to be area efficient with a newer solution, but they did it and successfully replaced it. But just a core ago, they introduced a novel decoding concept called clustered decode.
The team executes well enough to completely eliminate an idea to replace with a better one while improving the rest dramatically. They are aggressive, yet they execute.
Exactly is my point. But even that is shadowed by the very fact that AMD does just as good in performance, while keeping SMT, while behind in process(bit in performance, significantly in density), while being smaller!
All the theories don't matter. Real world results trump all. Which is that AMD is doing it far smaller, cheaper, and with less compromises.
Looks like your E core team consuming the P core team idea might have some legs.
Intel has recently begun work on a “unified core” to essentially merge both P and E cores together. Stephen Robinson, the Atom lead, is apparently leading the effort, so the core has a good chance to be based on Atom’s foundation.
Yeah their cores are better and scalable Intel's are not that all round it is the better solution P core team is not doing good work considering the competition otherwise LNL P cores would have to be like 10% faster at the same Power considering the node advantage they have vs Strix we will see with ARL
Seems like Intel have figured out how to achieve their +20% performance for Arrow Lake
Just lower the performance of Raptor Lake until you hit your targets 😛
its a strange coincidence that right before Arrow Lake launches, we get the final 13 & 14th gen fix, but this time the performance is hurting accoring to chiphell 🤷‍♀️
This has also been confirmed from the BIOS release notes by various motherboard vendors, which have released the 0x12B BIOS update for their LGA 1700. But as far as the performance goes, the Intel Core i9 13900K saw a noticeable 6.5% drop in performance in Cinbench R15. As seen in the screenshot, the Intel Core i9 13900K usually achieves 330-340 points in single-core performance with a similar configuration but with the latest 0x12B patch, the score dropped to 314 points.
If that's true, Arctic Wolf is probably the last separate effort before moving onto the unified one, if they just "started working on it".
Can they really get it done for the 2028 lake? Realistically they'll probably have to do another refresh of Nova lake before the new core is ready for the 2029 lake
Even if there are limitations on how many threads can be assigned to a given workload, power users can always find other applications to load up excess cores while multitasking. Having more cores just means not having to close programs as aggressively.
This is obvious: users should target the applications they want to run. No other benchmark will give them the exact answer they need. And this applies to all benchmarks beyond Geekbench. Cinebench is utterly non-representative in the way it scales, except for users who do rendering. Running games at very low resolutions is also completely stupid. Does this mean they are useless?
That being said, what CPU benchmark do you know launches multiple completely unrelated benchmarks to mimic what we users do (running a game with browser running, etc.)?
My point was you blaming Geekbench for not representing how *you* use your computer applies to all benchmarks. The problem is too many users pick aggregated scores of some random benchmarks and think this will represent the speed up they will get in their everyday use. And then you have people who dismiss some benchmark results because that doesn't fit their narrative about what CPU is better, but that's another discussion.
If this unified core rumor is true, which is already a long shot, I feel like it would most likely take form in a progressive transormation of the E cores rather than the "unification" taking place in one fell swoop at some point in the future. I don't think it would be current-Intel's style to bet it all on a moonshot 4 or 5 years away, iterative improvements to the E cores until they're ready to take over are probably a less risky endeavor.
Darkmont I think has been suggested to be a minor refresh of Skymont, but Arctic Wolf could already be something more than that.
My problem is if one buys top end Arrow lake there won't be a update till Nova Lake and is Nova Lake going to be on lga 1851? If its not then its not good.
This doesn't matter if you keep your CPUs for 4+ years but people who buy i9, R9s and soon Ultra 9s want the best chip and they update often.
Maybe this new core will be asymmetric? For example, one part will contain a single wide decoder and the other part will contain a cluster decoder. The cluster part could take over the second thread or support the main thread in ST.
Part of the blame is on the reviewers who have conditioned the audience to measure CPU performance in non-gaming workloads in Cinebench/other rendering benchmarks over the years. I'm truly baffled as to why I have to struggle to find browser benchmarks whenever a new CPU comes out when it's the single most relevant workload for most people. Everyone is using Chrome or have Discord (Electron)/Spotify (Chrome embedded framework) open in the background, but techtubers turn a blind eye to it.
That doesn't work well. Targeting high-performance and power-performance with the very same basic design will just result in cores that are not good at either target. I'm considering adding a car analogy, but won't 😀
Ouch. The one size fits all strikes back.
I have a really hard time believing this, especially as a rumor casually disseminated in the AMD subreddit, on a topic about Zen 5 3D.
What could make sense though would be branching out the E core design into future P and E projects, with similar building blocks in the form of an "unified architecture". That would imply a P core reset, but not an unified core as the size and perf. targets would still be complementary. It would be funny in a way, since it seems to me that AMD is doing the same thing, only starting from their P core instead.
I was thinking of the same thing. And looking at the changes in lion Cove:
Like the separate schedulers for INT and FP., the removal of AVX-512 and HT in client processors, et ... it seems the two designs are already becoming more and more similar (for the client SKUs atl east).
