Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 50 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
515
427
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E08 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E2CPU + IOD + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Arrow Lake Refresh (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXDesktop OnlyMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2025 ?Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E8P + 32E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ??8 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Tigerick
515
427
Guys, I have changed the the title of this thread to include discussions of Lunar Lake. Seems lIke LNL and ARL share lots of CPU architectures. GPU wise, there is rumor of integrated of Xe2 Battlemage graphics engine. And I mean integration of CPU & GPU within same die to save some power.
We will see how much power MTL-M would consume. Intel mentioned about 5W is only for tCPU which I thought would be enough for 2P+8E CPU. We do not know exact figures for SoC, IOE and tGPU. My guess would be around 20W for 4 tiles to function simultaneously.
That's why LNL being designed with different packaging in order to reduce power consumption.
Reactions: Joe NYC
poke01
600
582
Despite using the same CPU cores, Lunar Lake is an entirely different beast from Arrow Lake. It's probably the Intel product I'm most excited/curious about.
That Twitter photo is similar to M1. Lunar lake has onpackage memory or unified memory. This will redefine Intel's ultrabooks. If you used an ARM notebook, you willl notice the crazy standby time and how long the battery lasts and I am hoping that Intel will achieve that Lunar Lake while also being a powerhouse in its class.
To put Intel back on the map for business laptops and for mindshare Lunar Lake has to succeed. Apple used a simliar marketing approach, the M1 was efficient but also powerful. Intel has to show that it can also do the same.
Glo.
5,626
4,360
LNL is Intel's M1 - type product.
coercitiv
6,117
11,543
Removing half the E-cores to create a leadership product for ultrabooks. This will require a bit of digesting for the folks who believe that E cores are Intel's paradigm shift moment in the consumer space.
BorisTheBlade82
653
999
Maybe, they just realised, that 2 cores was/will be a bit too less?
Maybe, the distribution for common workloads scaling with 1, 2, 3, 4, ..., n threads just shifted a bit in recent years (80% Pareto might have been at 1.9 threads before and might sit at 3.1 now for example)?
IntelUser2000
8,686
3,785
It depends on the definition of what's needed. CPU and GPU is the most demanding part. If the CPU portion takes only 5W you could probably do all at 10W. And between CPU and GPU it heavily depends on what you are running.
I can tell you the PCH on my Kaby-Y doesn't use more than 1W at max and does not change significantly. It usually stays at about 0.3W. Bigger versions like the U set at 28W might use 2-3W at max at 1W normally?
The foundation of lowering system power comes with Meteorlake. The issue is that the PCH cannot power down fast enough in realistic scenarios, since even in Icelake it can reach ultra low standby power. What's the point of super low standby if it can only be reached literally after 2 mins of doing absolutely nothing, not even moving a mouse pointer?
This problem has been "known" for a decade now. I think if they did not screw up royally on the 10nm generation, we would have seen it quite a bit before 2020.
They might have a lot to perfect still, and that could be Lunar Lake.
Wake me up when they completely remove them. They are still experimenting with various setups. Also, you must also be dynamic with what you got. No set rule.
A///
4,352
3,154
I'll take non-sequitors for $1000, Alex (RIP).
ill risk the suspension by saying intel under pat "gunslinger" gelsinger is not looking at cuckholding themselves any further as they have the last five years due to amd clawing at them in datacenter, mobile and desktop. intel is still on a downward utilization trend in dc but will be held in place for a while due to outstanding contracts intel has. Once those end it's a free for all for amd provided they can meet the demand. there's a lot of factors of what or how amd can supply them but without having access to their and tsmc's records it's all a guessing game. this is why i said a while back that if intel investors aren't full of themselves and the board is smart they won't back a no confidence vote on gelsinger and will trudge on because they know he's laser focused onr ighting the many wrongs of the company.
gunslinger doesn't care about quick profits otherwise we wouldn't be seeing intel scrambling to get their timeline in order and he's not engaged in extra marital affairs like some of his predecessors. I don't look at mtl being canceled on desktop as a con. They may not see any financial benefit in developing it out for desktop when arrowlake will offer a more compelling reason to upgrade for older gen users or amd. If AMD's zen 5 is another lukewarm salad then it's all in intel's court.
Reactions: BorisTheBlade82
Joe NYC
1,864
2,147
I prefer Kissinger - which is what you get when you read Chinese article, mentioning Gelsinger, auto-translated to English.
Kissinger was the ultimate strategist in his era, and still is at age of nearly 100.
itsmydamnation
2,721
3,044
So which AMD processor is lukewarm salad? if your referring to Zen4 sales , that has nothing to do with Zen4 performance , its just market and timing. But its funny, for intel to keep up with the luke warm salad we have people running around saying just use DRR5-8000 its totally a daily driver!
