Page 461 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
In Specint they used icc putting others at a disadvantage. Also the 50% power reduction is in one benchmark, most real workloads only got about 30% power savings. Seems like Teams is the best case with 41% but it's still 20% behind X elite. 4K AV1 streaming they're claiming 33%, which based on MTL's 17W number translates to ~11W. That's still 3X of what M3 based MB Air draws and double the amount of power X Elite elite uses in this workload
Do you refer to soc power or total power usage? And from where do you get these numbers? In their AV1 4K demo MTL draw something like 12 watts total. Soc power is a fraction of this.
Exactly, and SoC power reduction propagates into rest of the system because it's a controller for the rest.
Youtube 4K AV1 demo shows the power consumption is like 5W for Lunarlake at the system level, not package level.
The power number is from notebookcheck X elite efficiency article where they used an external display. In intels demo both MTL LNL laptop screens are also off.
For Netflix streaming Lunar Lake can work 44% longer (26 hours) than MTL with 18 hours says Dell. The Qualcomm device can do 27 hours by the way.
For example, Dell is just now announcing a new version of its flagship $1,400 XPS 13 laptop with Lunar Lake that’s basically identical to the current model in every other way: same chassis, same dimensions, same screen, same 55 watt-hour battery pack. And yet, Dell says it now gets up to 26 hours of 1080p Netflix streaming at 150 nits of brightness, up from
18 hours previously.
That’s a 44 percent improvement, which is a giant leap for Intel, if true. (Never mind that the Qualcomm version of the XPS 13 quotes a slightly longer life of up to 27 hours.)
which could bring Meteorlake numbers down to what Intel shown
Yeah maybe they picked a wildly inefficient MTL implementation. Still even if LNL is 33% better than 11W MTL, they still need another LNL level uplift to at least get close to apple M series. The problem is that LNL is apparently a one off product and neither intel nor oems appear interested in competing with apple because of the LNL platform cost. Maybe Intel will look at LNL demand and decide to do another generation...
Yes but Intel video shows drop to 5-6W range, not 33% lower, it's nearly 50% lower. That is on Elite's level.
I'm also suspicious of "Idle power". They are using 7W with the screen off really? The Snapdragon uses 4W and 6W? Even the M3 uses 3W?
My 2017 Kabylake Yoga does 3W with screen-on. So my 2017 14nm Intel is superior to Apple M3 right? The problem is both Intel's and NBC's testing methodology is flawed. On battery the power management is better than on AC.
You can see some NBC tests showing "idle" power measurements at 4W, but the notebook is getting 20 hours on a 55WHr battery. Clearly it's way under 4W.
-4.4W Idle minimum.
-1.3W Reader(so not 100% idle) battery consumption. 34 hours on a 45W battery. Actually 1.2W since you can't use 100% of battery.
@cannedlake240 The package power difference between LNL and M3 might be closer than you think, if my suspicions above are true.
Apple does have an advantage of a tightly integrated system. Apple Intel Macbooks showed top tier battery life too, despite Intel hardware itself sucking in general.
Windows is crazy how much the process use compute for seemingly no reason, all the freaking time. This is why Skymont's power advances are a boon for Windows systems, cause realistically you can't get true idle on Windows. Especially not after 3+ months of using it!
They are dimwits driven solely by the greenback that's why.
Now I want to see the ST power consumption
ST power will be the same since they said >20% better performance, but 1/2 the performance at same power, which in tests like Cinebench where it loads the core you'll never see the CPU saying "Oh I'll perform just like the previous generation so I can use half the power.
In order for that to be useful it needs a general purpose workload equivalent of frame rate capping.
Intel laptops can have excellent battery life, even comparable to Apple in some cases, but at the cost of performance. Apple has both industry leading per core perf and stamina
You missed the whole point. Battery life isn't necessarily reflected by the tests and scrutinizing numbers is a waste of time.
And no, current Intel laptops are trash in terms of battery life. They can't even beat their x86 competitor and it spins up fans ridiculously and heats up chassis to do it. It makes Conroe vs Netburst comparisons look like an embarassment.
That doesn't yet count to Intel as its not in a laptop yet.
Neither is the M4 😉
Based on this:
and this:
Performance in spec2017 should thus be somewhere around 8.1. So the M4 is around 32% faster in integer for 1T in the iPad Pro. For the MacBook, one would think it would score a little better.
What is impressive though is what looks like a 29% jump from the 9 185H. Strange though as that’s way more than the 14% IPC increase for LNC vs RWC? Am I missing something here?
Neither is the M4 😉
I think you have mistaken me, Intel uses M3 instead of M4 because the latter is not in laptops is what I meant.
Although the definition of ultra slim systems is up to interpretation, I guess Intel means Windows or macOS machines here.
I cannot find post-launch SPEC2017 scores for SD X Elite, bar this one which was before launch.
That was running at 3.95 GHz. The SKU Intel compares with is running at 3.4 GHz. So it should score roughly 7.05 at 3.4 GHz instead of 8.19. So with the Intel Compiler, +61% over the SD X Elite puts the 288V at 11.35
That is basically tied with M4 in the iPad Pro, as per Geekerwan.
Obvious caveat is that this is ICC on Intel vs who-knows-what on the SD X Elite.
