Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 445 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
696
602
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E08 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
poke01
2,205
2,803
Please stop with it r23 it's one of the worst benchmarks. At least use 2024 version. In low power SoC MT matters very less. ST is where the focus should be.
No one is rendering blender scenes on a lunar laptop. Browser performance and standby time and video playback are the important metrics here. Throw in some video and photo editing too because these also compete with the base M chips and that's it.
Most of the lunar lake customers won't buy using cinebench scores.
Reactions: SiliconFly
13,738
It should be good for developers too. Almost as good or maybe better than Snapdragon laptops due to better Win32 compatibility. And of course, better Linux support.
SiliconFly
1,541
897
Very true. Running Win32 dev tools native is extremely important. Emulation just doesn't cut it. I used VMs for a while (very painful).
It would be interesting to see how lunar performs in code compilation.
Considering the performance, it should be able to handle small/mid size projects perfectly. If the code base runs into many millions of lines of code, then LL isn't the right choice.
ST Responsiveness light MT efficiency and battery life alongside gaming should be where LNL excel at not raw perf we have arrow lake h for that
Yep 👍
MS_AT
245
566
Could you share the setup? To my knowledge the only problem comes from using VMs to deal with the code that is on the host file system, therefore I am curious what else might go wrong since otherwise dev experience is usually the same if not better in case of poorly configured host.
Nothingness
3,089
2,083
Curious question about that. Are these developers fully married to the Mac ecosystem? Whatever binaries they are generating, can only be used on other Macs, if my understanding is correct? Maybe with some slight modification, their open source projects can work on Linux and other BSD derivative distros. And ok, maybe on Windows too with WSL2. But that's it, right? It's a niche of a niche. As far as I understand, they can't be doing anything with their Macs that sells well enough to non-Apple users. That's why I like the idea of Lunar Lake and Snapdragon Elite X. At least it will bring some happiness to regular Windows users who form the majority of the global personal computing userbase.
Among the OS you cite the only one I will never work on is Windows. I never could stand it and I only use it as a gaming OS.
Flash from the past: at the beginning of the century I was working in a startup making a compiler for chip verification; the IT guy only knew about Windows so all our machines were Windows; one day with a collegue we decided we had had enough with that abomination and we just installed Linux. We slowly converted the rest of the team working on the compiler (the GUI team was locked on Windows due to poor initial choice of non portable libraries). The negative impact on the compiler was exactly zero; we just made sure to write portable C++ code.
In my current company, all the engineering work is done on Linux (x86 or Arm). Some people work remotely on cluster/cloud machines (all Linux), so the host OS doesn't matter. I exclusively work locally before dispatching to the cluster, but it's really easy to write portable C/C++ code so developing on macOS (with command line tools, I don't use Xcode) is no issue. I guess I could also work on Windows with WSL2, or keep on doing what I've done for decades, that is working on Linux. But that mac I was lent has been a shock (speed, battery, silence), so I decided I could live with macOS (which I don't like, but it's less hostile to me than Windows).
Most engineers in my company run Linux natively. They start dropping it when they become managers and their life starts revolving around slides. At which point they switch to Windows or Mac (the latter representing the majority).
I don't pretend my experience and preference match the ones from others. I am in a niche, but for sure since my Windows experience at work, one of the most important criteria before changing job was to not have to ever run Windows.
To sum up: I work on portable SW that we have full control over (no non-portable dependencies), so my only need is to have something that looks like *NIX (and macOS with Brew certainly qualifies, as well, I guess, as Windows with WSL2). So my only criteria are laptop quality at large and at the moment Arm-based Apple laptops have my preference.
SiliconFly
1,541
897
File system performance hence build times vary too much between native and VMs. But, the most important part comes later. Running a test build on a VM isn't the same as running native.
Just out of curiosity, why would any windows developer want to run their ide/tools in a VM rather than native? Doesn't sound right.
Reactions: Nothingness
SiliconFly
1,541
897
I used to work on Linux a lot. But then switched to Windows for some projects. I know VS gets a lot of flak from the community, but once we start using it for a while, it grows on us. And it's obviously the best for Windows.
And most of my code I keep fully portable too (except for parts where it interacts with the system). I too strongly believe, keeping the code fully portable is the right thing to do.
(Sorry abt the rant. I know this is wrong thread for this topic. But just found that post very interesting.)
MS_AT
245
566
In one particular case we were using VMs to show IT dept their Windows config (Defender and some other software) was less than optimal, as pure Win install in a VM on the same machine was getting up to 50% better compile times for our projects. Not to mention VM was more consistent with timing of the builds. Then it's also less hassle to install all the tools if you can wrap them in Win container [Win on Win] but this is not always feasible.
SiliconFly
1,541
897
I used to work on a system software project where using VMs wasn't an option for debugging and testing. And we used to mess up the systems constantly during development/testing. Happens all the time.
But it was very easily addressed with imaging. Even in case of a full corruption it can bring the system back up to spec in less than 10 mins, byte-for-byte. Configuring/deploying images is as easy as maintaining/deploying VMs once the admins get the hang of it. I'm in so much love with imaging, I even use it for my personal laptops even today.
Tup3x
1,086
1,084
I don't know about that, especially if you happen to be a web dev (where pretty much everything is available for ARM already). X Elite does have advantage in multitasking and might be faster when running WSL2 + VS Code + gazillion browser windows/tabs. At times my current laptop (T14 Gen 1, Ryzen 7 PRO 4750U) is dog slow.
I don't think Lunar Lake would quite cut it. Without HT I'd want at least 12 cores, 32GB and higher TDP than 17W.
Compatibility reasons. Since most people in my team use Macs, things will just work if I run stuff in WSL2. Otherwise I'd have to make Windows specific build scripts for projects.
DavidC1
939
1,471
Lunarlake has a huge single thread and IO(memory/drive) system advantage. It helps worst case scenarios more than on average.
Read many instances of people saying how much Zen 3 was over Zen 1/2 or Skylake over Haswell or Alderlake vs Coffeelake. Usually min fps in gaming being a huge gain.
Computing advances always favor the lower power, lower cost, smaller devices more than the opposite.
ikjadoon
228
499
GB6 has a Clang compilation sub-score.
Clang
The Clang workload uses the Clang compiler to compile the Lua interpreter, a popular opensource language interpreter. It models the use case of developers building their code and the just-in-time compiling that general users can encounter on their systems (such as JIT compilation for scripting Java and compilation for shading languages in GPU drivers). This workload uses the musl libc as the C standard library for the compiled files.The Clang workload compiles 8 files in single-core mode and 96 files in multi-core mode.
The 268V scores 14514 nT points (71.5K lines / second) in the Clang subscore. I don't know which HX 370 laptops use a lower power limit, but the lower-wattage RPL Refresh SKUs (e.g., 2P+8E) like the 150U Clang subscore is 11661 nT points (57.4 Klines/sec).
The HX 370's Clang subscore whacks them both with 25474 nT (125.5 Klines/sec) at an unknown wattage.
288V SKU is 30W and 32GB RAM.
Another option I've posted in the GB6 thread.
I'm hopeful LNL mini-PCs allow a 'TDP Up' config of PL1 = PL2 = 30W on any SKU. That 288V (a Core Ultra 9) may be quite pricey and not offered by most OEMs.
ASUS Lunar Canyon reference NUC looks like it can cool 30W sustained on any SKU.
poke01
2,205
2,803
So not that impressive relative to the current competition. Disabling Hyper threading is hurting them here. I think Intel should have left that as an option. Lion cove isn’t the latest the ARM core where SMT isn’t needed. It still needs HT but I guess they removed it to show ST improvements.
Thanks for that.
Reactions: ikjadoon
Hulk
2,517
Cinebench has nothing to do with the software I actually run on my computers.
But it is a good benchmark for me because I know by heart how most chips perform with CB, and that in turn gives me a very accurate idea of how they perform in application that are important to me.
For example, my currrent laptop does about 3200 in CB R23 MT. A laptop scoring 10,000 in that bench will be about 3x faster than my current laptop.
CB is meaningless and full of meaning at the same time;)
DrMrLordX
22,065
11,693
Why would Hawx and Strix underperform 6800/6850U?
That's the point. Not even the Phoenix 8945H does 10.2K at 23W. The implication would be then that AMD regressed noticeably since Remembrandt in early 2022.
Maybe look for benches of the 6850u instead since that data is widely available:
Sorry to be "that guy" but this is an Intel thread, and not a thread for old AMD mobile SoCs.
It used to be a good fp benchmark. Now I'm not so sure, since fp has become so complicated with all the ISA extensions out there you can use, and some uarches do better with old stuff like SSE4.x than others, etc. Benchmarking has changed over the years.
poke01
2,205
2,803
I don’t get why some people show old AMD SKUs. There is nothing like Lunar Lake on the AMD side. It’s honestly the most advanced laptop x86 design in a long time and it will only be beaten by Strix Halo.
Yes, your old AMD U SKU will score much higher in cinebench but I doubt the power consumption is the same as well the responsiveness.
I bet that that Lunar will also beat the X Elite in battery life.
majord
493
641
Probably because the H SKU isn't optimised for thosecTDPs? I dunno, but that's not representative of U series such as 7840U
e.g:
10min loop settles on around 11K CB23 @ 17W package in their CB23 loop screenshot
Since many not convinced, here.. tested right now, not even clean run on a 2 yr old O/S
Hwinfo cleared at start of run for ave package power. Screenshot taken instant bench score appears:
24w avg: 9920cb
19w avg (balanced) 9089cb
12w avg: (power saver) 7088cb
and incase there's any doubt about package pwr readings..
5min loop 18.4w package, 22.8w battery draw w/ brightness low, wifi on
