Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 444 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
696
602
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E08 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
majord
493
641
For the 285K.
Previously It was 10212 pts in CB R23@30W, wich is about the same score at same power than a 18 months old 6C/12T 7540U, so they are quite late to the party, dunno why the excitement.
A 2 1/2 year old 8c 6800/6850U (zen 3+) does 10233 CB23 @ 23w
This is a complete dud @ throughput perf and perf/watt , despite half of its 8 cores being the fabled Skymont . Either Lion cove is shockingly bad, or Skymont isn't that great
its ST is strong courtesy of lion cove's brute performance , but at what power remains to be seen
Reactions: SiliconFly
mikk
4,247
2,311
8 threads vs 16 threads? In Cinebench is has a big impact.
Philste
253
447
2% faster than RPL in MTL to start with
What are you talking about? There is no "RPL IN MTL" RPL is RPL.
Zen 5 is more than 10% faster than Zen 4,
Zen 5c is the same architecture as Zen 5.
It's not in SpecINT, which is the more important of the two Spec Scores. Also different implementations of the same Arch don't necessarily have the same IPC.
Meteor Lakes LPE-Cores have way lower IPC than the one on ring and ZEN5c in Strix also gets hurt by only 8MB L3 for 8 Cores. So yes, Skymont on Ring in ARL-H should have the same IPC as Strix ZEN5c Cores and Clocks higher. ZEN5c clocks at 3.3GHz on both SKUs, even the LPE-Cores on LNL clock higher than that.
Reactions: DavidC1
Hulk
2,519
That CB R23 LL score has got to be wrong. Either clocks are horrendously low or that score is for P cores only. Actual score should be around 15,000.
majord
493
641
Apologies, I meant RWC on MTL . I though it was already established that Intel compared this specific implementation of RWC (i.e in meteor lake) to Skymont for IPC claims.
Pretty sure the true max clock speed of 5c on strix is 'unexplored' and assumed to be approx 4Ghz , but in any case, both Skymont and 5c are well out of their efficiency at Fmax , so probably moot.
About 1.2 x at the most? , doesn't really change much does it. turn SMT off and it still isn't looking flash if those numbers are legit.
13,738
I see mac devices being used by many SW developers. And we need fast and efficient parallel builds. My 4 yo MBP can last all day running parallel builds and running mostly ST compute heavy tasks. It remains to be seen if Intel will be able to match that.
Is that a niche? Surely 😀
Curious question about that. Are these developers fully married to the Mac ecosystem? Whatever binaries they are generating, can only be used on other Macs, if my understanding is correct? Maybe with some slight modification, their open source projects can work on Linux and other BSD derivative distros. And ok, maybe on Windows too with WSL2. But that's it, right? It's a niche of a niche. As far as I understand, they can't be doing anything with their Macs that sells well enough to non-Apple users. That's why I like the idea of Lunar Lake and Snapdragon Elite X. At least it will bring some happiness to regular Windows users who form the majority of the global personal computing userbase.
Abwx
11,557
4,349
Skymont was compared to Raptor Cove, Lion Cove was compared to Redwood Cove.
SKT score about 1595 pts at 4.6GHz in CB R23, and i would estimate that it score in the SSE4.2 restrained CB R15 something like 245 pts at this same frequency, there s no way it could match RPL.
ikjadoon
228
499
yuri69
541
975
How does that help the masses? Websites I can understand but how many websites are running on Macs? There are no real Mac servers.
Mac as development tool probably provides faster feedback loop (running tests, building locally, etc.) leading to shorter development time. That's the end user benefit.
Abwx
11,557
4,349
As it can be seen from the above graph, Jaykhin's results mean that LL is (presumably at 17 W PL1) competitive with Strix Point at 15 W package power
At 30W it score 10200 while Strix Point in this curve score 10000 at 15W.
Assuming that ARL s P cores have only 1% better IPC than Zen 5 in CB R23, wich is dubbious since CB traditionaly favour Intel but let s take this basis to not under estimate SKT, then at their max all core frequency, wich is 5.4GHz, ARL s 8 P cores score 17600 pts.
Since the total score is 43118 pts this imply that the 16 e cores at 4.6GHz score 25518 pts, wich amount to 1595 pts/core/4.6GHz and about 4% better than a 5600X wich score 1536 pts at about the same frequency.
And given that Intel got a 10% perf/clock uplift vs AMD in CB R23 comparatively to CB R15 then Zen 3 should have 1.1/1.04 = 5.7% better IPC in CB R15, so overall SKT and Zen 3 should have comparable IPC as far as we re talking CB R23 + CB R15.
Abwx
11,557
4,349
It can score ZERO in Cinebench for all I care. It has no relevance to how people use their laptops.
It had a relevance a few posts ago :
Lol of a lol, talk of being of bad faith, guess that the ignore button is the way.
DokiDoki
47
77
46
That comment was me correcting @majord's false claim that Zen 3+ scores 10000 points at 23W. Beyond that it has no relevance to me.
The only one who engages in masturbation using Cinebench scores in this forum, and, more often than not, by using ONLY one source - Computerbase - is YOU.
Don't worry - I won't be flooding your notifications by replying to you any longer.
