Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 430 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
695
601
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
dttprofessor
56
14
51
How good will latency be on Arrow Lake.
I know now on a tile instead of monolithic die, but isn't it monolithic on a tile instead of 10nm? Like
So wouldn't it still be much better than AMD chiplets because its a ring bus on the tile and all cores on ring bus and Intel designing it like that? So could latency be as good as the 10nm Alder and Raptor Lake?
BEOL OK
NOC ?
TESKATLIPOKA
2,508
3,009
Core Ultra 3 is expected to have 4P + 4E cores.
Should be a huge upgrade in MT perf over current gen i3.
Considering both RPL and MTL have only 2P+4E It's not really surprising that nT will be better.
BTW, what do you consider as a huge upgrade? +30% or more in nT?
Here is a table where I compare mobile MTL vs ARL. Not accurate, just an example of how much better It could be.
MTL P-core: 100 points
MTL P-core HT: 25 points
MTL E-core: 65 points
ARL P-core: 110 points
ARL E-core: 90 points
Thread countUltra 3 105UL 2P+4EARL 4P+4EDifference in %
1100110+10%
2200220+10%
3265330+24.5%
4330440+33.3%
5395530+34.2%
6460620+34.7%
7485710+46.4%
8510800+56.9%
Reactions: cebri1
cebri1
348
370
3% seems a bit too low based on the information we have. Maybe there are latency issues? If it's a 14% IPC increase over of RWC, and 0.3 less GHZ... it doesn't add up.
Even if it only had 10% IPC increase over RPC, 1nT should still provide about a 5% ST improvement.
MT is going to murder the 14900K .
dullard
25,479
3,976
I don't know specifically about the MTL 105UL, but has any recent Intel chip actually gotten even close to 25% from hyperthreading on average? Maybe on a very specific benchmark or two, but that is far from the norm.
Intel's hyperthreading never gained as much as AMD's version did. I think the most generous assumptions would be 20% and that isn't often the case. Here is an example (admittedly gaming focused) where the HT ON lowers the average performance and if you go on a few seconds in the video the individual differences ranged from -8.6% to +3.7%. Never close to 25%.
Basically doing a generic table with 25% just seems to only be reasonable for the few niche areas where HT does the very, very best and that is generally in artificial loads that keep all threads active at 100% at all times.
Abwx
11,536
4,323
That s not true, at the time Hardware.fr made a comparison and the difference wasnt huge, and since those days Intel has improved their SMT capability, they even talked of up to 30%.
22.47% chez Intel, et 25.6% chez AMD
Wolverine2349
392
117
How will big.little hybrid work with Arrow Lake.
Because Skymont is so much better than Gracemont, will all the Big.Little hybrid scheduling issues be completed solved and all software should work perfectly as it would on homogenous with hybrid Arrow Lake?
Or no is hybrid still a potential issue for some software regardless of dramatically improved e-cores.
gdansk
2,890
4,363
Realistically, assuming P core is 1.14x faster and at 5.7GHz while E core maxes out at 4.6GHz, then any high priority thread scheduled on the E cluster is at ~0.7x performance it would have on a P core.
So it won't make scheduling any easier but does reduce the penalty when it messes up.
dullard
25,479
3,976
You linked a situation where Intel's HT gained less (22.5%) than AMD's SMT (25.6% to 28% if core parking is disabled). That just supports my statement.
Plus, I would hope we look at something more recent than HEDT Broadwell-E for debates on how Meteor Lake's hyperthreading performs. As time went on, for newer chips, HT performed less and less and less. More cores meant less reason for HT, better use of the core meant fewer idle resources, and more power limit stretching just meant that HT's transistor flipping added more heat and more thermal throttling.
TESKATLIPOKA
2,508
3,009
Doesn't look like that or It's dependent on thread count and If HT is usable in that APP or not.
I made another table for desktop, tried to be more accurate, but this is still just a guess!
14900KS vs QS ARL in CB R23
RPL P-core: 197 points (5.9GHz all-core Turbo, 50% higher IPC than E-core)
RPL P-core HT: 49 points (1/4 of P-core)
RPL E-core: 100 points (4.5GHz all-core Turbo)
ARL P-core: 206 points (5.4GHz all-core Turbo, 14% higher IPC than RPL P-core)
ARL E-core: 148 points (4.6GHz all-core Turbo, 45% higher IPC than RPL E-core)
Thread count14900KS 8P+16EQS ARL 8P+16EDifference in %
1197206+4.6%
2394412+4.6%
3591618+4.6%
4788824+4.6%
59851030+4.6%
611821236+4.6%
713791442+4.6%
815761648+4.6%
916761796+7.2%
1017761944+9.5%
1118762092+11.5%
1219762240+13.4%
1320762388+15%
1421762536+16.5%
1522762684+17.9%
1623762832+19.2%
1724762980+20.4%
1825763128+21.4%
1926763276+22.4%
2027763424+23.3%
2128763572+24.2%
2229763720+25%
2330763868+25.8%
2431764016+26.5%
2532254016+24.5%
2632744016+22.7%
2733234016+20.9%
2833724016+19.1%
2934214016+17.4%
3034704016+15.7%
3135194016+14.1%
3235684016+12.6%
Of course the biggest difference will be at 24 threads, I got +26.5%. Don't forget this table is just my guesswork.
Reactions: Det0x and cebri1
Abwx
11,536
4,323
You linked a situation where Intel's HT gained less than AMD's SMT. That just supports my statement.
3% yield difference at the time, that s marginal, and as said it has been improved in recent uarchs, IIRC it s 31% in Cinebench for Intel and something like 32% for AMD.
For a 8C/16T this amount to 2 extra cores at worse and as much as 2.5C at best.
The reason to drop the SMT capability lies elsewhere, they thought that each SMT thread could be replaced by a small core that has much more throughput, on paper that make sense but on practice that s not as straightfoward, because a small core cost more silicon and power wise than three pieces of HT circuitry for 3 P cores.
dullard
25,479
3,976
With Meteor Lake, the scheduler had Big, Little, Little-LPE, and HT on Big cores. Four totally different ways that adding a thread would impact performance. And four drastically different performance levels between them. Probably the most difficult to schedule correctly is when the Big core is impacted to add in an HT thread and suddenly needs to share cache with that other thread.
With Arrow Lake, it is a bit easier. (1) There are only three types Big, Little, Little-LPE. (2) The performance delta between types of cores is less. (3) Resources on the Big cores are more reliably known if another thread is added like with HT (it doesn't have to suddenly share cache or swap back and fourth with processing threads).
Plus, hopefully more and more software keeps getting written to identify the proper core for each thread.
dullard
25,479
3,976
Look at averages, not cherry pick single software benchmarks written to put all threads at 100% at all times. The average HT performance change is way less (closer to 10% to 15% depending on software in the average) for Intel. Not so much of a drop for AMD in average SMT on/off.
Or wait 2.5 weeks for Lunar Lake to come out. That might be better than speculating. Hopefully we get some reviews that cover the differences.
Wolverine2349
392
117
Though Desktop Arrow Lake, there are no LPE cores right.
All P and e-cores on same die right and only 2 types of places to put threads right?
dullard
25,479
3,976
That would make scheduling even easier with just 2 types of cores--especially without as much performance delta between them. I have seen conflicting rumors about whether or not Arrow Lake reuses Meteor Lake's tile with the LPE cores though. At this point I don't know--hard to keep the rumors straight.
Abwx
11,536
4,323
Look at averages, not cherry pick single software benchmarks written to put all threads at 100% at all times. The average HT performance change is way less (closer to 10% to 15% depending on software in the average) for Intel. Not so much for AMD.
At this rate you dont even need to add more cores, because the point is precisely to increase the max throughput, otherwise why would they implement more cores..?.
So the apps that benefit substancialy of SMT in Hardware.fr test are 7 ZIP, Winrar, DxO Optics, Visual Studio, GCC, Stockfish, Komodo, X264 encoding, 3DS Max with Mental Ray and Vray as plugins., that is, almost all tested apps.
That s a lot, and as you can see there s not even Cinema 4D or many other softs that are known to benefit from SMT, otherwise the 7950X would trail a 14900K in almost all apps if not a 14700K.
dullard
25,479
3,976
Again, I wouldn't use that Hardware.fr benchmark link for conclusions of modern day CPU comparisons. The article is over 7.5 years old on ~8 year old CPUs.
Here are SMT gains over the years. To make it as lenient towards your argument as possible, I'll exclude gaming results which show SMT declines in more cases than not.
I could go on and on with links. In the average software, AMD's SMT gained more than Intel's HT. As the years go on, SMT's improvement is getting less and less on average. Then adding to that decline, Spectre / Meltdown mitigations destroyed much of the HT gains that Intel had. And in no average was Intel getting +25% as used in the table that sparked my discussion. The only average where AMD got at least +32% as claimed in this thread above was from 10 years ago.
inf64
3,864
4,546
I know that this is about ArrowLake and impact of SMT in benchmarks, but for Zen5/Zen5c the performance impact on Linux is 18% (geomean of 57 workloads) with no measurable impact on power consumption:
"Simultaneous Multi-Threading (SMT) still proved very much useful for AMD Strix Point with the new Zen 5/5C cores. Contrary to Intel abandoning Hyper Threading (HT/SMT) with Lunar Lake, SMT was providing measurable performance gains across a wide mix of multi-threaded workloads. The impact of SMT varied but when taking the geometric mean of 57 benchmarks in full, SMT on the Ryzen AI 9 HX 370 was around 1.18x the performance of running this 12-core Zen 5/5C laptop SoC with SMT disabled.
Equally important is that leaving SMT enabled on this AMD Ryzen AI 300 series laptop did not negatively impact the CPU power consumption. Overall the CPU package power consumption averaged out to being the same across both runs."
Reactions: Saylick
IEC
14,440
5,429
I'm holding out hope that Arrow Lake is competitive (and fixes Intel 13th/14th gen stability issues) so I have an excuse to build or upgrade another system in the next six months.
On the other hand, the realist in me expects marginal gains overall with some regressions. There are just too many known items working against ARL:
1) Clock speed regression (even vs most optimistic "leaks")
2) Tile architecture = there will be some performance regressions due to this (latency and power penalties vs monolithic)
3) Lack of SMT
4) New platform/motherboards - I expect some things to be broken at launch judging from recent Intel and non-Intel launches
Not too much longer til we know for sure.
Reactions: KompuKare and inf64
inf64
3,864
4,546
3) Lack of SMT
Gaming performance will be hard to predict due to tile uarchitecture and it's possible impact on latency. On the other hand, ST and MT performance should be fairly predictable , with some caveats (average IPC boost of 14% for P core and 35% for E core, all core boost of 5.4Ghz/4.7Ghz for ARL and 5.6Ghz/4.4Ghz for RPL; SMT adds 20% performance on avg. for RPL)
ST
RPL 14900K- relative ST performance 1.0 with 6Ghz boost
ARL 285K (5.7Ghz ST boost )- relative ST performance : 5.7/6 x 1.14 = 1.083 or around 8% faster
MT
RPL 14900K- relative MT performance with 5.6Ghz/4.4Ghz all core P/E boost : 8 x 1.2 + 16 = 25.6
ARL 285K - relative MT performance with 5.4Ghz/4.7Ghz all core P/E boost and no SMT : (8 x 5.4/5.6 x 1.14) + (16 x 1.35 x 4.7/4.4) = 31.86 => around 25% faster
