Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 425 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
694
600
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
255
182
Shareholders don't realise how difficult,costly is to run FAB Manufacturing Buisness is especially in West Due to labour and various other stuff.There is a reason only Intel, Samsung,TSMC are the only 3 Leading edge logic Fab.Fab reporting from intel was going to be worse either way due to the horrendous cost structure of Intel 7 .
KompuKare
1,163
1,426
Arrow Lake: the new generation CPUs have at least 100W lower power consumption while maintaining high frequecnies. The updated process eliminates previous high voltage issues, ensuring stability.
Performance details of the new generation are confidential but expected to be impressive.
Today leaks power plan of Arrow Lake...Still a lot for 3nm jump for Core Ultra 9 :)... 295W powerlimit on Intel Extreme profile (pushed for reviewers)View attachment 104901
The one thing I was hoping for from Intel was a return to saner power limits. This does not bode well.
gdansk
2,836
4,218
Doesn't Samsung have one of their large 8nm fabs in Texas?
Not leading edge anymore but it was at the time and it seems they're planning to do it again.
Anyway I realize now this isn't the Intel financials thread.
dullard
25,476
3,976
So lets assume this table is correct (I didn't see any source that Jaykihn references).
  • There are 14 power drops (median 19.8% lower power setting). This is across all chips and all power settings of each chip.
  • There is 1 power setting increase (16.6% up but only for the i9, PL2, extreme power setting).
And you call that not boding well?
inquiss
179
261
I really don't see the investors having a case here. "Feeling misled" certainly isn't evidence. They need to point to specific lies.
They can talk about the "state of fabs" all they want - but Intel didn't ever have to report on the independent finances of fabs when they were a vertically integrated and proprietary to Intel's own internal designs. There were no "independent finances" of fabs prior to them being split off just like there's no independent profitability report of the HR department or IT department reported to investors.
Yeah, as I said I'm not talking about the intel case. More the general point that it's not always investors fault. There are exceptions.
Reactions: Tlh97
ondma
2,997
1,519
Can the premiere take place earlier?
Wont say, "I told you so" but ...... (not directed at you specifically)
I have said many times that ARL will be a 2025 product, ~6 months behind Zen5, trading blows in performance, and still using more power.
Intel may have caught a break, though, in that so far Zen 5 doesn't seem to be a home run either, especially in gaming.
Edit: Intel says ARL launch is not affected (yea, right), so I could still be wrong. But I still think good availability, even on desktop, wont be until 2025.
jdubs03
678
304
ondma
2,997
1,519
Less than 20% power drop going from 7(or 10??) nm to 3 nm seems like a mediocre improvement, unless performance is significantly improved, which seems unlikely. And AMD has proven it is possible to get similar performance at much lower power. Intel's big cores desperately need a ground up redesign.
Geddagod
1,295
1,368
I actually think LNC, Zen 4, and funnily enough Zen 5 along with that, are all going to have spectacularly similar spec2017 INT core/ring-power perf/watt graphs when Huang tests them out in a couple of weeks.
dullard
25,476
3,976
I would be careful with calling it less than 20% power drop. You are glossing over a lot of details there. Go with maximum power level settings to be more accurate. How long the CPUs are at their maximums determines the actual power usage.
Performance is significantly improved, but probably mostly in areas that you will claim not to care about.
inquiss
179
261
I'm really sure why you're quoting me, I said I'm not commenting on this case for intel. To be clear, I'm not commenting on intel.
ondma
2,997
1,519
I was using your numbers, dude.
511
255
182
The disappointing part would be Skymomt beating Zen4/RPC at low power level 🤣
Philste
248
442
These PLs are wild. ARL looks bad but a the same time PTL-H is only 64W PL2 with 16 Cores and 1536 ALU iGPU. I mean MTL-U has 57W PL2 being a 2+8 with 512 ALUs.
OriAr
93
84
A 4P+4E Core Ultra 3 would be amazing value for the sub $150 market while demolishing anything AMD has to offer in that price range.
Should offer a big MT performance boost over previous gen as well, and gaming performance will be more than good enough for that price range.
DavidC1
778
1,236
Another Intel mistake. Cancelling hybrid Falcon Shores.
AMD on MI300 announced that it's the fastest product to reach $1 billion in revenue. In this dire time, $1 billion could have been a boon to Intel. I doubt it's just "AIeee" why companies are snapping up MI300. Combined high performance CPU/GPU has many other uses and it's a unique product.
Along the way of "saving" money Intel will inevitably make more long term mistakes. Sure, maybe when all 110K employees are gone and the company goes down they'll save $20 billion per year!
Thanks for the link, there’s too many products now, can’t keep up with them all. Has the 500 W for Turin been confirmed? I haven’t seen it in any of the AMD stuff.
The 192 core Turin Dense and 128 core Turin are both 500W.
DavidC1
778
1,236
Explain to me what PL2 has to do with battery life...
Does it mean Panther Lake can POTENTIALLY use more power than Lunar Lake? Yes!
Does it mean it WILL use more power than Lunar Lake? No!
Of course you are absolutely right. But take that into account with other factors.
-Pantherlake has one more tile, separating the GPU tile.
-Does it have the System Level Cache?
-What about the power optimized LPDDR PHY?
-Lunarlake will achieve fantastic battery life with just two core types. Why does Pantherlake add LPe again?
img_2693-jpeg.99480
Look how the LPE core uses more power at the same frequency than the regular E core. Not by a small amount either. E core is using about 3W and the LPE is using more than 5W.
According to the above graph, they could have just skipped the LPE core and let the regular E core cluster handle it and it would have actually saved quite a bit of power. This is in fact what Lunarlake does. In LNL presentations sometimes it seems they attribute power savings entirely to the Skymont cluster.
Everytime you are jumping to another cluster you have delays in making the previous core sleep and waking up the new one. Having three means more delays, and more delays mean less opportunity for power savings.
DavidC1
778
1,236
Hopefully It won't have a third core type like ARL-H in the SoC tile.
BTW, MTL-U is 2P+8E+2LPE.
Pantherlake does have the LPE core again. I'm not sure if it's with other cores or in the PCD.
It has three active tiles: GPU, Compute/NPU, PCD or Platform Controller Die. It has two additional tiles but they are passive and for structural support.
I think the problem they have with MTL's LPE core not working to save power isn't just the slowness of it. Since you need to hand the state of the machine from one core type to the other and it has to happen very, very fast(milliseconds), there will be a point when both of the tiles have to be active. If that period is too long you aren't saving power.
Also you are adding redundant circuitry, because if you are turning one tile off entirely you have to have two of them. I think they mentioned that regarding media in the MTL presentation.
