Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 423 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
695
601
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Det0x
1,262
3,991
Gaming averages at 1080p. Between 10-15%, depending on the benchmarks used.
Pick whatever game collection you want, which dictates if its 10%, 15%, 20% or 25%
It dont really matter for the point i'm trying to make..
The performance increase going from vanilla Z5 to Z5X3D will be larger than going from vanilla Z4 to Z4X3D
And since i have already said too much, i will leave it at that
TwistedAndy
159
150
LPE and E live on the same tile. And they have the new core topology (Which I believe debuts with ARL? Not sure) which allows LPE cores to be used on any workloads. It's a proper, Arm like, multi-cluster scheduler scheme this time. Unlike MTL weird one.
Arrow Lake is expected to use a very similar topology to Meteor Lake.
10-15% difference in package power is 4-5% in system power. The changes at the package level can induce a change elsewhere, but Meteorlake battery life tests basically confirm they basically are back to the pre-Icelake era. They regressed since then.
Meteor Lake is probably below the initial Intel's targets, but it's pretty good in terms of battery life and power consumption under light loads:
~10-20 hours under the Notebookcheck's web surfing test is a good result.
Obviously, battery life is not the best metric for measuring power efficiency, but it's pretty representative.
DavidC1
831
1,306
Percentages multiply, not add/subtract.
This part isn't adhered to as strictly as people think. The original Pentium Pro reveal by Intel showed percentages as additions. When you consider that the CPU gets further from the memory as clock increases, then the small difference gets lost through noise.
Also we must remember during the sane days Intel used to give a range rather than oddly specific numbers. It was "15-20%" rather than "19%" which is silly to the level of retarded. But the x86 competition also decided to copy them in that regard too.
Arrowlake is 10-15% faster per clock, which is almost Haswell/Skylake levels of gains(or lack thereof).
But that's what people care about. Load battery life is essentially dependent on TDP. It's battery life that's difficult to achieve.
The system has a huge 99WHr battery, which is the absolute limit. At 50WHr which used to be standard until not too long ago, it's mediocre at best. It's Kabylake levels.
SiliconFly
1,531
882
Now comes the kicker, dont expect Z5X3D to run at the same clockspeed as Z4X3D ;)
At this point, I don't expect much from competition. Twitter/X has already labelled Zen 5 as Zen 5% due to the meager performance increase. ARL-S is easily gonna surpass Zen 5 this generation. I think it's gonna take a X3D to even barely compete with the top end ARL sku. Now it makes sense why Intel is going for a simple ARL refresh next year instead of a significant upgrade.
Det0x
1,262
3,991
Well, its one thing to think, hope and expect
But its a other thing when you have hardware in hand
Lets just say we will get a repeat in the builders thread, come embargo date
Reactions: Tlh97 and IEC
AcrosTinus
93
84
51
I went through the entire release news of the competition, the ball is now in Intel's court.
Give me 10% more ST perf. and 75W less peak power usage and I'm good. Maybe make sure you don't lose the low latency advantage due to the tiles.
Restrict everything to solid defaults and leave performance on the table ! Revive the OC part of "K" instead of giving us max. OC CPUs with no headroom and high voltage.
Reactions: SiliconFly
maddie
4,881
4,951
Two threads, two poles and none for the main.
Tup3x
1,079
1,079
10% more performance (doesn't hurt if applies to MT too) and power usage between 140W-175W for 7 & 9 tier. That would be win.
SiliconFly
1,531
882
10% ST perf is pretty much a given at this point. May go a bit higher if ARL's LNC is a bit different from LNL's LNC than what some have suggested. Dunno much about power usage numbers (never really cared), but considering ARL-S is getting two solid full-node jumps, efficiency too is a given. Being on N3B and still being as power inefficient as Raptor Lake is simply out of question.
This year, ARL top sku is all set to compete comfortably with top-end Zen5 X3D and may even win by a narrow margin. The Zen advantage has finally come to a conclusion. We now have a pretty much level playing field.
jdubs03
804
408
Interesting choice there. Probably a cost saving measure, but not sure that is really a value add. Only for H-series SKUs.
SiliconFly
1,531
882
It's known for ages that Arrow Lake reuses Meteor Lakes SoC-Tiles, so it was clear it will also have 2 Crestmont cores.
Yep. It's sad that crestmont still lives. But I'm hoping the ARL-H cpu tile design takes that disadvantage into account. Waiting for the cpu tile die shot.
You guys are setting yourselves up for disappointment if you believe in SiliconFly's fantastical optimism.
What does it take for a supermod to believe in me? I can revised it down to 9% if it's acceptable. Many have mentioned this before. Putting it all together, anything less I believe is simply out of bounds if you ask me.
SiliconFly
1,531
882
To be honest, the only thing I expect is much lower power consumption while performance is probably about the same.
Tbh, I don't think even Intel can squander a 14% IPC increase to "probably about the same". Not feasible at all.
14% to 10% -> The minimum some (including me) are expecting (I'd say maybe more that 10).
14% to upper single digit -> Most popular expectation.
14% to 0% gains -> Not feasible.
Reactions: AcrosTinus
