Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 413 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
695
601
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Magio
77
78
51
The 30 W Ultra 9 288V exists solely for giving the iGPU more oomph, and will therefore be used mainly in gaming-centric designs.
Also, the Prestige 13 Meteor Lake had pretty meh cooling.
I wouldn't hold my breath for any magical MT improvements. 12-13K in GB6 MT is the upper limit of what it may achieve.
Also, there is no '30 W sustained' or, for that matter any fixed power limit in Intel Mobile CPU land unless you disable DTT using Throttlestop. So comparisons of MT score, especially on different laptop models, is meaningless.
Of course I'm not expecting a 2x (or even 1.5x) from the 17W parts in CPU benchmarks, but a measurable improvement would be welcome. It's highly unlikely to compete with a 28W Strix part in MT CPU tasks, though.
And it's not a hard coded guarantee, but you'd expect a good design around a 30W PL1 part to at least be able to sustain close to 30W, just like you'd expect those that will ship the 17W SKUs to sustain roughly 17W with short bursts at 30W.
511
401
259
PTL-U is just a cheaper LNL variant from Intel i am more excited about PTL-H with 4+8+4 + 12 Xe3 cores if it can give LNL battery with 3050-3060 mobile Gpu performance it will be solid but it will be bandwidth starved if it's still at 128bit i wish they make the mc support 192bit as an option
Reactions: Ghostsonplanets
Magio
77
78
51
The thing with PTL-U is it's hard to imagine it be that compelling an option at the top end when that Dell leaked roadmap says the early 2026 XPS 13 redesign will still ship with LNL (and Oryon V2), only getting a refresh when NVL-U drops in early 2027.
511
401
259
Those are leaked roadmap and are bound to change they are 2-3+ year in future crazy things can happen if PTL-U is pin compatible with LNL. which it should be maybe?
SteinFG
635
767
Zen 5 competition will be arrow lake hx and h not lunar lake.. lunar lake competition is m2 m3
AMD's Zen 5 line is their most efficient, they will definitely compete with lunar lake. Especially Kraken. Kraken and Lunar wil have comparable ST numbers, and Kraken will win by some% in MT. They'll probably be close in efficiency. Gaming perf should be similar too, I hope.
FlameTail
3,855
2,297
Lunar Lake will crush Kraken in gaming, becuase LNL has a fatter GPU.
Reactions: Henry swagger
exquisitechar
683
940
Using basic napkin math, it appears Lunar Lake could have an IPC advantage against Zen 5.
Zen 5 has +7% int and +12% fp advantage over Redwood Cove and Lion Cove is advertised as having a +14% IPC increase over Redwood Cove.
Looks like it. That int performance is pretty bad considering the breadth of the changes in Zen5. People were right about AMD's IPC claims/questionable benchmark choices, it's the first time that they aren't representative of overall performance at all and it shows in SPEC.
Ghostsonplanets
685
1,111
PTL should adopt LNL 8533 LP5X memory controller (Or even be improved to support 9600/10700T). Besides, Intel has a lot of cache (8MB) for the iGPU. So their designs aren't as memory bandwidth starved as the competitors.
Intel problem really was that their GPU IP nor their software stack were ready for the prime time. Which is something I suppose will be fixed by the time Panther Lake comes to market. Because, otherwise, they seem to be much more serious and giving more area consideration towards iGPU performance than AMD for example.
Abwx
11,536
4,323
Intel s 14% is comparable to AMD s 16%, that is, an average of various softwares, not only Spec, you are implying here that LNL will also have 14% uplift in Spec.
Reactions: Nothingness
511
401
259
Btw an interesting thing with the LNC slide in LNL it shows that Intel 4 is superior to N3B at high power assuming +14% IPC it means intel was not lying about their Intel 4/3 providing same P/W as N3 derivative
511
401
259
Yeah as Xe2 will give us a glimpse of their effort too bad BK ran the company to ground no innovation nothing It took gelsinger to correct predecessors mistake he is just dumping money in fabs and their core buisness
Abwx
11,536
4,323
LNL CPU use TSMC s N3 while MTL CPU use Intel 4.
DavidC1
830
1,306
Where's the Wave that claims that Arrowlake is awesome now? It comparatively sucks much less than 2 days ago isn't it?
:p
I do speculate though Lion Cove may be similar in that FP gains are going to be greater than Int. No, it's practically guaranteed with the 4 FP units.
Efficiency at this level is pretty much battery life, which Lunarlake should be significantly better at.
Reactions: exquisitechar
DavidC1
830
1,306
I know but if we take 14% IPC as avg uplift at higher curver Intel 4 is better than N3B this method has its flaws
Intel sucks on mobile for this very reason. The whole company has been in the mindset of highest performance transistors for 30 years.
Therefore it is natural that at the peak clocks, Intel processes are better. But in Lunarlake and Server products, TSMC is better.
Reactions: 511
