Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 340 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
695
601
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Or how about a hypothetical 12 core Skymont only desktop CPU. Best option for non hybrid gaming CPU for more than 8 cores in one tile/die/ring? Or does the design of it prevent such a thing even if Skymont IPC really does achieve Golden Cove levels and high 4.XGHz clocks?
Or would real world performance not be that great with the deign by itself and not supplemented by the Lion Cove cores?
Or other weaknesses (latency???) such as latency of Skymont where it would not perform even clock normalized 4.6GHz close across 100% workloads as Golden Cove?
Or would real world performance at 4.6GHz clock normalized by on par across almost all apps as a hypothetical 4.6GHz all 12 P core 12th Gen GLC with HT disabled?
To be fair, having separate pmics per score/pcore cluster and with scheduling prioritised to ecores, lunar lake won’t take a major power efficiency hit from p-cores unless they are needed
Reactions: carancho
DavidC1
831
1,306
I didn't, check the graphs at 8:35 and 9:40:
Skymont est. (MTL LPE + 38% INT +68% FP) = 1.90 INT 2.86 FP
Ultra 5 125H E 5.66 INT 6.44 FP @ 3.6GHz = 1.57 INT 1.79 FP
i9 14900K E 5.64 INT 6.01 FP @ 3.6GHz = 1.57 INT 1.67 FP
i5 13500H E 5.11 INT 5.79 FP @ 3.5GHz = 1.46 INT 1.65 FP
Ultra 5 125H LPE 3.44 INT 4.26 FP @ 2.5GHz = 1.38 INT 1.70 FP
People making the argument that because it's compared to an LPE core it'll trash in performance are making incorrect assumptions, when Intel themselves said there's 5% difference. Not only that, Lunarlake doesn't have a dedicated L3 cache to itself. It needs to share with many other entities and meant for power saving over performance.
There's also the fact that it's faster than Raptorlake when Sunny and Golden got 18% and 19% over Skylake, the supposed equivalence to Gracemont.
DavidC1
831
1,306
Lol, the recent events make me more convinced than ever that Eric Quinnell knows what he is talking about and uop caches are going the way of Hyperthreading.
Think about it. We had to back off from pipeline stages because adding stages is a guaranteed loss, while prediction is not.
Netburst architectures demonstrated that additional stages cost way more transistors than initially anticipated.
Since the process technologies keep getting better and better still, the idea is to cut the stages again:
-Which improves performance just by itself
-Simplifies design, thus less area and power use, thus more efficient
-Which allows for higher performance by using it elsewhere
Apple has the shortest pipeline at 9. It's that simple.
Jun 4, 2024
Lunar Lake E Cores are now able to talk to each other through their L1 cache, which should dramatically improve core - core latency: https://hothardware.com/reviews/intel-lunar-lake-deep-dive?page=3
Meaning we avoid this in Arrow Lake: https://www.anandtech.com/show/1704...hybrid-performance-brings-hybrid-complexity/6
Previously core communication required trip through ring bus, or in case of LP cores, Meteor Lake’s LP Scalable Fabric. See also https://chipsandcheese.com/2024/05/13/meteor-lakes-e-cores-crestmont-makes-incremental-progress/
Damned good design changes
Saylick
3,512
7,766
I'm guessing you're talking about this? https://vighneshiyer.com/misc/tesla-talk/Eric_Quinnell_Tesla_Talk.pdf
Interesting read.
Jun 4, 2024
I didn’t realize this but Skymont can be thought of as wider than Lion Cove (9 wide vs 8 wide, when the core can extract enough parallelism).
And has greater single threaded performance than Lion Cove, just can’t clock as high, and doesn’t scale with power as well. But we can fit 3 of them for every lion cove core. Exciting for a future that prioritizes threaded workloads.
Reactions: Henry swagger
Hulk
2,416
If we go by AMD and Intel's numbers, Arrow lake looks like it will lose single thread performance to Zen 5. I don't know why people care so much about the e-cores.
The E's have been somewhat helpful is you have apps that are highly multithreaded. They haven't been that strong from a compute point of view. That is all changed now. If Skymont lives up to Intel's hype we're talking about E cores that are Raptor Cove equivalents IPC-wise.
Lots of people have posted many times, "Just give us 12 P cores." Well how about 16 P cores, plus an additional 8 that are even stronger!
Jun 4, 2024
It actually has around 20% performance advantage at iso power.
Edit: and although intel’s graphs are non specific they indicate that the entire raptor cove power curve is shifted up
Hulk
2,416
Seriously? This thread is getting way ahead of itself. I thought I saw leaks that Zen 5 will have similar clocks, and dont forget ARL is giving up hyperthreading, so the E cores better be really good. ARL will still have to have a really good IPC increase for the P cores to beat Zen 5.
Perhaps, perhaps not.
Let's look at CB R23 MT. If Lion Cove is +15% over Raptor Cove and can do 5.4GHz nT and Skymont IS Raptor Cove IPC-wise and runs at 4.6GHz, then 8+16 ARL will do 48,000 points. That would be remarkable especially considering the lack of HT in Lion Cove. If Lion Cove in ARL get HT then we're looking at a score of 54,000 points.
We shall see if Intel has been fibbing with this recent information.
Hulk
2,416
I would suggest watching the High Yield video. Skymont looks like an absolute beast. It looks like you can still fit 3x Skymonts in the area of a single Lion Cove.
Shame that so much of the die is eaten up by this new NPU. I would have preferred to rather spend that die area on another 4 Skymonts and making the iGPU a bit bigger but the AI NPU wars cannot be stopped at this point.
When Intel starts spamming these new Skymonts (or future mont cores) in huge numbers, it should lead to some ridiculous MT performance and PPW.
LNL's implementation of LNC will not have HT but HT versions of LNC absolutely do exist. It isn't yet known if ARL has HT or not.
NPU-wars are so enticing for manufactures. The fruit is nice an low, easy to reach at this point in time. CPU fruit is much harder to reach.
Reactions: lightmanek
H433x0n
1,177
1,529
This generation x86 was kinda disappointing, eh?
Zen5 = 16% IPC, iso clock
LNL P-core = 14% IPC, clock regression (?)
Zen 5 is not 16% IPC. Look at how they calculated that “16%” figure with some weird cherry picked Geekbench sub tests. If they used the same series of tests that they used on Lion Cove it would not net a 16% increase.
Jun 4, 2024
Also Intel stated that at iso power Lion Cove in Lunar Lame is up to an 18% performance uplift, not 14. Just depends on where you sit on the power curve.
Something most are missing is theyre describing 14% uplift in the Lunar Lake iteration, not in all implementations.
poke01
2,094
2,626
Intel made some really good changes in client. CPU industry is in a good spot.
By the way anyone know the area of Skymont?
H433x0n
1,177
1,529
Also Intel stated that at iso power Lion Cove is up to an 18% performance uplift, not 14. Just depends on where you sit on the power curve. Theyre not juicing to the gills this time around so we get 14% in Lunar Lake.
Something most are missing is theyre describing 14% uplift in the Lunar Lake iteration.
Yeah, it’s entirely possible LNC in ARL-S ends up being 1-2% higher too with the added L2$.
The more I learn about Lion Cove the better it appears. It’s not as wide as expected, the ROB barely increased over Golden Cove. The power characteristics are significantly better over Golden Cove.
Reactions: invisible_city
Ghostsonplanets
685
1,111
Another tidbit from Chips n' Cheese:
However, while the L2 can in theory do up to about 110B per cycle Intel has made the engineering choice on Lunar Lake to limit the L1 to L2 bandwidth to 64B per cycle for power and area savings.
So we're looking at possibilities of, on Arrow Lake DT:
- Bigger cache
- Return of HT
- L1 to L2 bandwidth to 110B per cycle
Intel new modern sea of cells design really allow for finer grained changes that fit different markers. Quite interesting.
Wolverine2349
392
117
Or better yet Skymont only CPU disable the P cores and hten the dream of a 12 to 16 P core non hybrid Raptor Lake CPU is real. Well the clock speed, but if it can get to slightly above 5GHz and no caveats meaning it truly would perform across all work loads (excluding AVX512) as a hypothetical 12 to 16 P core clock normalized Raptor Lake HT disabled no caveats.
That way no scheduling hybrid gimmicks and you can get the 12-16 P Core Raptor Lake in Skymont by purchasing Arrow Lake disable Lion Cove cores and you got real Raptor Lake P cores. No HT but 12-16 cores HT would disabled.
Is this actually a real possibility or too good to be true.
QuickyDuck
18
23
41
On the bright side, with SRF intel can finally compete with 4th gen EPYC.
On the dark side, they are actually compete with 5th gen EPYC.
Still looking forward to skymont, hope they get ppa right.
