Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 337 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
695
601
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Wolverine2349
392
117
The atom core is good. But some Intel users might anyway decide to shut them down to gain better P core OC and compatibility in some situation.
And if you care atom core enough, you should have known E core IPC is already quite good, compare Gracemont to Goldencove is just 16% lower on INT, and 38% lower on FP due to less FPU resources.
Guess why Intel compare Skymont to LP Crestmont in Meteorlake which lacks L3 cache.
Yes will be the thing to do if they have a more than 8 P cores on any model in single tile. Otherwise, a waste to do so and just get 9700X or 9800X3D for only 8 cores of similar performance. Unless you just love Intel and are ok with losing SMT with only 8 cores.
DavidC1
831
1,306
Gracemont is around skylake IPC. Skymont is around Raptor Cove IPC, which is a jump of around 20-50% (specint int 20%, fp 50%) AND gets a clock boost.
What are you smoking? Sunny Cove is 18% faster than Skylake and Golden Cove is 19% faster than Sunny.
Skymont is 38% faster than Gracemont. This is a blowout increase alone, but there's also a 68% FP increase coming from the straight up doubling of FP performance, which will benefit vast majority of applications from beginning of the FP era, without needing to recompile like AVX512.
Skymont's FP unit is more capable than Golden Cove in
-64-bit FP: Literally everything
-128-bit FP: Everything from Core 2
-256-bit FP: Somewhat worse.
Assuming Int/FP split of 65/35%, that's a 50% gain. In 2022 it was Raptor Lake with Gracemont, and Golden Cove enhanced, and Zen 4.
Reactions: Tlh97 and Hulk
Henry swagger
496
301
In two years,
-P core Intel got 14% gain
-P core AMD got 16% gain
-E core Intel got 50% gain
Three years of 14%: 48%
Three years of 16%: 56%
Conclusion 1: Three times two year gains of P cores delivered in 2 years. Feast on that. I had a good feeling the E core team will make a breakout someday.
Conclulsion 2: 50% is Bulldozer to Zen level gains. Unlike Bulldozer though Gracemont was pretty good already.
Where is intel's e team based at ?
DavidC1
831
1,306
In two years,
-P core Intel got 14% gains
-P core AMD got 16% gains
-E core Intel got 50% gains
Skylake was late 2015. So it took the Intel P core team 9 years to deliver 60% gains. E core team did it in two.
Saylick
3,512
7,766
You can't read the slides either :)
The vs raptor cove is not Lunar Lake LP Skymont vs Raptor Cove, but an undisclosed (Arrow Lake) implementation where the Skymont cluster is on the ring bus (and shares L3 with P-cores)
Username checks out.
Point is, Intel is using a L3 cache for these Skymont comparisons.
DavidC1
831
1,306
Yes.
But it isn't L5. The system level cache is mostly for power saving purposes by reducing distance of data access ala Apple Mx chips. The performance advantage of the system level cache won't be as significant as having L3 cache.
gdansk
2,890
4,363
Yes.
It can still access it though? Why is the nomenclature L# is not applicable.
DavidC1
831
1,306
Levels suggest that it has to always go through it before main memory, or the next level. It is called system wide cache for a reason. Such a broad cache will also not be as performant as a dedicated cache.
gdansk
2,890
4,363
So L4 is filled directly from memory and doesn't look in the last level cache first?
Jun 4, 2024
Taking my figures from this IPC comparison of Gracemont, which is thought to be around Skylake IPC and Golden Cove: https://www.techpowerup.com/298887/...n-4-and-golden-cove-spring-surprising-results. That being said, Intel has previously said Gracemont outperforms Skylake, which I forgot about.
You're right that Intel's stated IPC is 19% average over Cypress Cove, which is ~19% above Skylake, or around 35%. The numbers don't make sense, must be relying on different workloads for comparison.
DavidC1
831
1,306
Taking my figures from this IPC comparison of Gracemont, which is known to be around Skylake IPC and Golden Cove: https://www.techpowerup.com/298887/...n-4-and-golden-cove-spring-surprising-results
Back in Gracemont days, Intel said it was approximately like Skylake without giving explicit figures. We found out that the FP is substantially slower(66% advantage for Golden Cove, meaning Skylake is likely 20% or so faster), and even in Integer it wasn't fully up to par.
Now they are saying it'll outright outperform Raptor Cove.
Jun 4, 2024
So in Lunar Lake the cache structure for the P core is as follows:
L1 (48K),
L2 (192K),
L3 (2.5MB),
L4 (12MB),
L5 (8MB)
Is that right?
Intel has stated that while L5/SLC is accessible to p-cores, in practice hit p-cores don't need/use L5, and keep in mind that this is shared between NPU and e-cores. More useful to think of Lunar Lake as 2 subsystems, P-cores with L1 - 4, E-cores with l1-3
Jun 4, 2024
My point is that the the uplift over non-LP gracemont must be on the order of 20% for int and 50% for fp in Specint, adroc's fud notwithstanding.
Forgot to mention that intel state's on average LP gracemont IPC is down only ~5% with non-LP.
DavidC1
831
1,306
Intel has stated that while L5/SLC is accessible to p-cores, in practice hit rate is low, and keep in mind that this is shared between NPU and e-cores. More useful to think of Lunar Lake as 2 subsystems, P-cores with L1 - 4, E-cores with l1-3
The idea is to put everything in the cache as much as possible. So without the system level cache, the caches are for the cores only. Now it has a dedicated one for all uncore and I/O. Sharing reduces performance and increases latency so all units sharing will be low performance*, but for saving power it'll do wonders.
DavidC1
831
1,306
Gracemont is actually slightly slower than Skylake in Int and something like 20% slower in FP if we take 66% Golden Cove and divide by 19% and 18%.
If it's 2% faster than Raptor Cove it'll be about 30% in Int.
Thoughts on Darkmont and Arctic Wolf:
-Darkmont is basically a Tick with few % improvements
-Arctic Wolf is the big one again with roughly 30% for Integer.
Jun 4, 2024
Mental math: order 20%=~30%. Raptor Cove vs Gracemont INT IPC in that techpowerup article is around 6.8 for Raptor Cove vs 5.53 for Gracemont 13th gen, 23%. Anyway, splitting hairs. My only point is that Adroc is throwing down some red herring cap by focusing on the fact that the comparison Intel drew was to LP cores.
DavidC1
831
1,306
Lunar Lake does sound excellent. I had a feeling they could pull it off. I had a mixed feeling for both Lakefield and Meteorlake, though I always thought it was possible to do good in theory.
40% lower video playback power is 60% higher battery life. Now we're cooking.
ondma
2,999
1,520
Dnt worry 8+32 model should take care of zen 5 and zen6
Depends on the use case, that is if we ever even see 8+32.. Should be great for embarrassingly parallel workloads, but more E cores wont help for gaming. Personally, I would rather see more P cores than continued spamming of E cores. If they feel the need, AMD has already stated they could increase core counts too.
Jun 4, 2024
Yeah, this is the first time I've felt like Intel is executing since the early aughts. Fairchild/Intel was an innovation powerhouse. The beancounters almost sank them. This is a return to form, and we're seeing just the beginning of it. This is Intel's 2003 Dothan moment.
dullard
25,479
3,976
P cores do well when fed massive amounts of power. If you just keep adding P cores, then within a given power budget, each subsequent P core gets less and less power. Meaning, very soon you get P cores with not enough power to work well. It could actually perform worse in games unless you get a CPU with a pitiful base clock and a massive power hungry turbo clock--but only turbo for the right number of cores to match your game.
If power use and heat dissipation weren't issues, then your desire would be great. But, in a real world situation, no chip can follow your dream path.
An army can't just double the number of soldiers, but give them no more food and no more supplies than an army half its size requires, and expect this starving army to perform well.
