Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 292 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
686
574
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E08 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Arrow Lake Refresh (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXDesktop OnlyMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2025 ?Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E8P + 32E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ??8 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Hulk
2,216
My experience running Photoshop, Digital video and audio software, vector illustration, Topaz video/photo ai, Handbrake, ... the rest is easy on the CPU (Office, Chrome, etc..)
Given strong P cores and enough E's, HT isn't a benefit to most people outside of DC and benchmarking.
Most software only uses (heavily) around 6 to 8 cores and of those usually 2 or 3 are the ones carrying most of the load from what I see in HWinfo.
A lot of compute intensive applications harness the GPU pretty well.
For these reasons I have HT off on my 14900K. Run the P's and E's at 5.5/4.3 and it's always under 200W, generally under 150W for most tasks. It runs 70C max on air and around 1.1V under load. Except for Cinebench performance is no better with HT on but heat and voltage are much higher.
If the P's and E's in Arrow Lake are +20% over Raptor/Gracemont IPC-wise and the efficiency is better I'll be in for an upgrade. 15% might even do it for me assuming it can hit 5.3/4.0 all-core.
But then again over the years I've turned into an upgrade junkie. I kept my Haswell for like 7 years and then over the course of 3 ripped through a 12700K, 13900K (degradation warranty return), 13600K, and now 14900K. It's too much fun to upgrade and I have the disposable income to fool around a bit more than years past where I would eat beans and coos coos every night because it was cheap and keep the heat on 60 F.
Ghostsonplanets
500
890
It's amazing what RPL can do when using sensible settings. Instead Intel decided to clock it to the moon to keep up with AMD.
I still remember when Geekerwan underclocked and undervolted an i9 12900K while disabling 2P cores and locking it to 35W. It could still compete with M1 Pro. Everyone was so amazed and hopeful that ADL Mobile would be very efficient...But alas.
Hulk
2,216
If I wanted to really work I could put a custom loop on it, maybe even a chiller and get maybe 8% more performance for like $500 and a ton of electricity use.
Not worth it for me and it doesn't sound like fun to buy or build.
5.5/4.3 is easy for the 14900K at under 1.1V under load with HT off.
Intel did what they had to do in order to post benchmarks. The non K parts and even the K parts in pre-built systems are set up to run in a sane manner. Most people buying K parts I think know how to set them up so I personally like Intel selling me the chip with specs indicating what it can do under extreme cooling and power. The user can back that off to what is reasonable for them.
coercitiv
6,343
12,602
None of Intels current lineup is even close to Apple in performance per watt.
That's why the entire exchange is funny, it quickly went from "exclusive LLM functionat enablement on day 0" to an unfavorable comparison against a passively cooled, 3+ year old product from the competition.
It's the marketing bug I guess, that "exclusive" was too hard to resist. In Robert's partial defense though, it's also the AI bug, people can't help saying things without checking when it comes to generative AI claims.
Gideon
1,697
3,891
OT, but looking at your sig, and the taxing applications you listed, I'd say the biggest upgrade for you would be going for low-latency DDR5 6400 MT/s (or higher if your mem-controller can handle it).
Just going from 4400 MT/s DDR5 to 6400 DDR5 makes a notable difference in video editing and photoshop:
Let alone moving from DDR4 to DDR4 (TBF, they were using some horrific JEDEC timings for 3200 Mhz CL22) :
Those apps tend to like more memory bandwidth and the way DDR5 banks are set up, it is able to deliver more real-world bandwidth even at the same MT/s.
It would obviously make the most sense to time it with the Arrow Lake upgrade (as it's mem-controller hopefully is also improved).
I'm actually quite envious at the prices in the US for 64GB DDR5 kits, with excellent latency and speed that will run on most 12-14th gen CPUs:
Reactions: Hulk
Ghostsonplanets
500
890
Our beloved Intel Core Ultra 5 115U makes another appearance(s). We have 2P Redwood Cove + 4E Crestmont + 2LPE Cresmont, for a total of 8C/10T. On the GPU side, it mark the first appearance for Intel Arc Xe LPG 48EU.
Basically, 115U is the binned/reject version for the MTL-U, akin to the role of i3 1215U on ADL-U line-up. The CPU side sees an entire 4C Cluster of Crestmont disabled. And the GPU sees an Xe Core (16 EUs) disabled within the Render Slice.
Also, for fun:
1C/1T@1GHz. Reject multicore, embrace single core😁
Khato
1,221
275
While I won't claim that there couldn't be some binned chips, almost all U series chips, including the 115U, are going to be using the dedicated 2P/8E and 64EU tiles rather than cut-down 6P/8E and 128EU tiles. Basically the exact same as the U series on ADL/RPL have a separate die.
Also, if anyone wants a full review of a 165U such is now available on notebookcheck - https://www.notebookcheck.net/Core-...ell-Latitude-9450-2-in-1-review.825254.0.html Pretty much as expected - slightly lower multi-thread performance, about 2/3 GPU performance, and notably better battery life. It is unfortunate that Intel didn't include the full GPU tile on any of the U series SKUs, but I guess we'll effectively be getting that with LNL.
Ghostsonplanets
500
890
Aye. Hence why I said the 115U sees an 4C CRT cluster disabled and a Xe Core (16 EUs) out of 4/1RS.
Much thanks for the link! Was waiting for the review since they had added some results in the database some days ago.
Hitman928
5,527
8,598
Better battery life (outside of load situation) is probably mostly due to the lower power screen being used compared to the previously reviewed MTL laptops with OLED screens.
Reactions: lightmanek
Ghostsonplanets
500
890
MTL no haz XMX
Oh, i'm aware. I thought DP4a was executed through the XMX units on Xe HPG and thus MTL LPG wouldn’t support it due to lacking it. Bit of a "braindead" moment.
Coming back to this: CPU performance is unimpressive and fail behind its peers (And even RPL-U in some tests). GPU is actually pretty good! 64 EU LPG is ahead of Iris Xe 96 EU and relatively close to the 128 EU in some tests. Active battery life is an amazing improvement over the past generation. But, somehow, idle power has increased and thus idle battery life is lower than RPL-U🫠.
Overall, MTL-U seems to be a pretty good upgrade for anyone on TGL-U and before. ADL/RPL-U users won't benefit much due basically no improvement on CPU side, despite the others IPs and perf/W being an significant improvement.
On the matters of availability, I have seen very few offerings, if any, of MTL-U based devices in the wild. It seems it has been a very slow ramp up (Or the costs x benefit calculus is massively on RPL 282 side).
Let's see if Intel can get some design wins in the <$600 market until the end of the year. I assume Core Ultra 5 115U will be the key volume driver in this price bracket, if such ramp-up happens of course...(Projected 40M shipments until EoY).
Otherwise, I think it's best to wait until ARL-U announcement at CES, as it will be priced cheaper and will have a perf/W bump due to Intel 3. But certainly will be a challenging and extremely competitive landscape for MTL/ARL-U due to AMD and QCOM offerings.
Ghostsonplanets
500
890
With MTL Intel now has an NPU in a laptop chip. Inly a a year after AMD and 3 years after Apple but despite that it has cutting edge AI marketing.
MTL NPU is basically a "saving face" IP. Specially given how late it is. But, if there's a thing Intel is really good at, is at at pushing marketing narratives and flexing their human capital and developer relationships with ISV so that their products are well supported. MTL NPU having so much support day 1 is an example of this.
Khato
1,221
275
Yup. As some have been pointing out all along, MTL battery life looked bad on the initial models due to the OLED displays. Still don't have any MTL reviews from notebookcheck with a plain boring 1080p screen that'd compare against the majority of Phoenix laptops, but I'm sure it'll happen eventually. For now this is how the various MTL and PHX laptops which notebookcheck has reviewed stack up when sorted by their corresponding display size/resolution. Save for the PHX Tuxedo Pulse 14 Gen3, MTL is always on par or better on the WiFi test thus far. And MTL is clearly winning on the H.264 playback metric.
WhH.264WiFi 1.3H.264 min/WhWiFi min/Wh
https://www.notebookcheck.net/HP-El...en-7-7840U-and-unbeatable-price.754141.0.html14" 1920x1200 60Hz IPS5176077914.9015.27PHX
https://www.notebookcheck.net/HP-ZB...e-notebook-that-relies-on-Zen-4.759343.0.html14" 1920x1200 60Hz IPS5178215.33PHX
https://www.notebookcheck.net/Lenov...n-power-in-the-compact-ThinkPad.786912.0.html14" 1920x1200 60Hz IPS52.572913.89PHX
https://www.notebookcheck.net/Lenov...-laptop-is-better-with-AMD-Zen4.763581.0.html14" 1920x1200 60Hz IPS5798879317.3313.91PHX
https://www.notebookcheck.net/Lenov...w-fast-portable-straightforward.795741.0.html14" 1920x1200 60Hz IPS5259268511.3813.17PHX
https://www.notebookcheck.net/HP-El...ness-laptop-ruined-by-Sure-View.809651.0.html16" 1920x1200 60Hz IPS7683992411.0412.16PHX
https://www.notebookcheck.net/Frame...h-better-than-the-Intel-version.756613.0.html13.5" 2256x1504 60Hz IPS6172611.90PHX
https://www.notebookcheck.net/Dell-...ce-RTX-for-integrated-Intel-Arc.813905.0.html14" 2240x1400 60Hz IPS6474911.70MTL
https://www.notebookcheck.net/Core-...ell-Latitude-9450-2-in-1-review.825254.0.html14" 2560x1600 60Hz IPS6081513.58MTL
https://www.notebookcheck.net/Lenov...Zen4-isn-t-automatically-better.787943.0.html14.5" 2560x1600 90Hz IPS7373761810.108.47PHX
https://www.notebookcheck.net/MSI-P...-Core-i7-Xe-to-Core-Ultra-7-Arc.785587.0.html16 2560x1600 60Hz IPS99.9110011.01MTL
https://www.notebookcheck.net/Lenov...Intel-Arc-confronts-Radeon-780M.810926.0.html14.5" 3072x1920 120Hz IPS736809.32MTL
https://www.notebookcheck.net/MSI-P...-7-and-OLED-weighing-under-1-kg.810670.0.html13.3" 2880x1800 60Hz OLED75100269413.369.25MTL
https://www.notebookcheck.net/Tuxed...h-AMD-Zen4-and-a-120-Hz-display.795476.0.html14" 2880x1800 120Hz OLED605956209.9210.33PHX
https://www.notebookcheck.net/Lenov...ighter-with-faster-Arc-graphics.821145.0.html14" 2880x1800 120Hz OLED756008.00MTL
https://www.notebookcheck.net/Asus-...th-120-Hz-OLED-and-Core-Ultra-7.805236.0.html14" 2880x1800 120Hz OLED75101070713.479.43MTL
https://www.notebookcheck.net/2-in-...Core-Ultra-allrounder-with-OLED.807431.0.html16" 2880x1800 120Hz OLED8386271710.398.64MTL
https://www.notebookcheck.net/Galax...ive-to-the-Apple-MacBook-Air-15.821005.0.html16" 2880x1800 120Hz OLED76114464415.058.47MTL
https://www.notebookcheck.net/Lenov...-inside-this-workstation-laptop.796559.0.html16" 3840x2400 60Hz OLED847976359.497.56PHX
S'renne
61
Even though AMD has an NPU on their APU SoCs a year earlier than Intel, there's like no news on what software its actually supported on isnt it? Not even ROCm/Pytorch while Intel already has their own AI/ML support when people demo'ed running stable diffusion before MTL got released.
Earlier released hardware means nothing when there's barely anything you can do on it a year later...
Ghostsonplanets
500
890
iirc although AMD released Phoenix with an NPU, neither was the NPU exposed to software developers, outside of some (MS Teams), neither was the NPU mandatory as the OEM could enable it or disable the NPU functionality if they wanted it. So more or less what you said, yeah.
S'renne
61
Idek why people tout that Intel lags behind with CPU SoC hardware like their NPU for the current topic, they've always went for the optimal software/hardware support for their processors(besides Arc) and that's more important than raw performance imo.
SiliconFly
1,127
576
Yup. As some have been pointing out all along, MTL battery life looked bad on the initial models due to the OLED displays... ... MTL is always on par or better on the WiFi test thus far. And MTL is clearly winning on the H.264 playback metric.
In spite of everything, MTL performance is still only on par with previous gen (and that was a bit of a disappointment for me).
And it's battery life is also only on par with the competition (in spite of all the power saving tech). Well, there are a few scenarios where it does provide better results. But there is no clear win and that speaks volumes.
MTL no haz XMX
I thought DP4a was executed through the XMX units on Xe HPG...
XMX is pretty much necessary these days but isn't mandatory. MTL can definitely live without it.
I don't think it's a fair comparison. When AMD released it's NPU, there weren't many mainstream AI apps to begin with. Today, we have enough apps and more mainstream apps are integrating AI/LLMs as we speak. Things are just getting started and AMD was actually on the leading edge. Forget day 0 for a moment, today all those CPUs support AI and that matters a lot.
Reactions: spursindonesia
