Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 276 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
650
535
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E08 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Arrow Lake Refresh (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXDesktop OnlyMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2025 ?Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E8P + 32E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ??8 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
tamz_msc
3,795
3,621
People are too stuck up on how LP E-cores work on MTL to think that just because the Skymont cores in Lunar Lake are a different cluster with their own SLC, they are functionally similar to those of MTL.
It is obvious that they are still utilized whenever needed, even if the heavy-lifting is being done by the P-cores.
Reactions: mikk
DavidC1
170
233
Perhaps rather than using a harsh tone and making a judgment on people, you might want to take a second look at the official Intel leak that says the E cores are for low priority applications.
tamz_msc
3,795
3,621
That does not mean that when running something like Cinebench MT, those cores are sitting idle.
Reactions: mikk
SiliconFly
1,033
534
ARL is Core Ultra 2xx after all...
And it also says, ARL will have 2 LPE cores in the I/O die.
Worst part is, RPL-H refresh is getting refreshed again! Thats just sad!
Reactions: lightmanek
Hulk
2,007
I'm so confused about Arrow Lake. Can someone answer the following questions with the best available info/evidence?
Will Arrow Lake be desktop only or desktop and mobile?
What is known about core counts/configurations?
What node(s) will it be using?
Will the P cores have hyperthreading?
I realize we don't have hard information at this point. I'm just curious as to what the best evidence supports regarding these questions.
Ghostsonplanets
201
296
IO die? I guess this is a workaround to the fact it's reusing MTL SoC Tile and thus it would have to reuse Crestmont as the LPE core.
1 - Both. Mobile Intel next year will be composed on RPL U/H, MTL U, ARL U/H and LNL MX.
2 - Mobile up to 6P/8E. Desktop up to 8P/16E
3 - Intel 20A for some mobile dies. N3B for Desktop and Mobile (Including LNL)
4 - No. HT is done for the foreseeable future. Speculation now says Intel will replace it with Rental Units or whatever it comes from the fabled Royal Core/Exciting new Core project.
Reactions: Tlh97 and Hulk
SiliconFly
1,033
534
0IO die? I guess this is a workaround to the fact it's reusing MTL SoC Tile and thus it would have to reuse Crestmont as the LPE core.
Also, I think there is a Arrow Lake H or HX mobile 8P/16E cpu (based on N3B).
That would make, ARL-H on 20A. ARL-HX & LNL-MX on N3B.
DavidC1
170
233
The latest report from Bionic_Squash and others say Arrowlake 20A is only on 6+8 Desktop, and the rest are N3.
Other reports said Arrowlake does not have the useless LPE core. I think Videocard report is just speculation.
Up next is likely the uop cache once they give up fanatical focus on clocks.
Hitman928
5,259
7,855
What's up with this? I assume this test was completed running Windows? Will this CPU actually be more performant and efficient than Inte/AMD offerings when we see it in laptops?
SPD-X will be mostly competing against Zen 5 and ARL. With that in mind, if we are to believe the rumors and consider this SPD-X score as final, then Zen 5 will have a significant performance lead and ARL a slight performance lead. Efficiency I won't comment on since we don't have actual power numbers yet for any of them.
Edit: The reference laptop they used as a demo machine had much better scores. Not sure what makes the "in the wild" scores so much lower but probably comes down to immature firmware.
dullard
25,055
3,408
That type of CPU is exactly why I've been saying that we shouldn't have AMD vs Intel fights. The real battle is ARM vs x86. AMD and Intel are on the same x86 team. Any infighting between them deflects attention from the real upcoming war against ARM.
moinmoin
4,944
7,656
Right, Intel and the x86 ecosystem as a whole are lucky to have AMD. Otherwise ARM would be seen as a clear winner for quite some time already. AMD's comeback took the wind out of a lot of ARM sails over the years (be it ARM servers, be it Apple Silicon, etc.). It's actually quite telling that plenty comparisons over the years were about ARM chips compared with Intel chips.
Henry swagger
364
238
86
Lol
Hulk
2,007
How is this ARM cpu able to compete with native x86 designs? It must be using some type of emulation, which is normally a performance killer?
gdansk
2,081
2,570
Microsoft has included an x86 and x64 emulator in ARM builds of Windows for sometime now.
Ex-microsoft employee Darek Mihochka, who lead development of this feature, goes over a history here of their emulation here: http://www.emulators.com/docs/abc_history_of_woa.htm
(he's now at Nvidia which @FlameTail may find interesting)
Schmide
5,587
718
Comes to mind. Arm has some cool instructions, ironically kind of complex, like VLD that permute RGB elements better than x86.
