Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 254 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
781
748
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Henry swagger
509
312
I tend toward believing the Mercury Research market share numbers rather than any individual retailer - https://www.tomshardware.com/pc-com...new-mercury-research-data-shares-q4-2023-data
Simple fact is that Intel knows how to sell its processors on the client side as evidenced by their revenue share being higher than their unit share. Consumer marketing/brand recognition combined with supporting OEM designs goes a long way in selling products. Being notably ahead on the technical merits of the product is primarily helping AMD on the large scale server deployments.
Plus intel has a more trusted and known brand with quality
Hulk
3,660
I am disappointed at the lack of hyperthreading or increased E cores, but considering all the E cores in 14900k I doubt that HT adds 20% to overall performance.
You are right, it's 15% in CB. Still significant.
The increase in the P cores is 30% (in CB) due to HT. 389 pts/GHz to 512 pts/GHz, but that is of course mitigated in the overall scores due to the non-HT E cores. Still 15% right off the bat just to break even is a lot, plus they have to make up for the decrease in frequency AND tile latency.
That's about 20%. Let's say they get +20% from Raptor Cove to Lion Cove, which I think is a lot, and Skymont makes up 10% of the MT deficit. We could see 10% improvement from Lion Cove. Except for the fact that they could be losing 10% in frequency! Every time I do the math on this it just seems really tough for Intel to beat Raptor Lake at the top of the stack.
The MT problem is even more severe down the stack where the ratio of P to E cores increases.
Hulk
3,660
When Intel already has 10 cores in their lowest i5 SKU, the lack of HT in ARL will be more of a spreadsheet problem than a consumer problem. The only thing they need to do is increase core count for Ultra 3 or whatever they'll call it (the current i3).
Without even looking for actual measurements, with the conventional wisdom of "1P=2E" and "SMT=20-25%" we should be looking at a 10-12% loss in MT due to removal of SMT... and that's in Cinememe scores since for actual workloads SMT thread should be the last in the queue and most consumer workloads simply won't scale beyond the E core spam.
All we really need from ARL is stronger ST perf and minimized latency tradeoffs due to tiled structure.
Good estimates. Using my CB data with an 8+16 part they are looking at having to make up 15% for MT in the worst case Cinebench "ridiculously multi-threaded scenario.
Of course the issue is exacerbated with parts down the stack where the P to E core ratio increases.
SiliconFly
1,925
1,284
Of course I'm not overlooking the additional transistor budget afforded by a node shrink. That is the basis for architectural improvements. My point is that the move to tiles, lack of HT, and extremely high Intel 7 clocks make the normal jump all the more difficult. They have to gain A LOT of IPC just to break even.
Since it's a bit more than a 2X node jump for LNC, it's gonna get a huge transistor budget due to the massive density increase which should easily compensate for the loss in Fmax. The same way Apple & Zen get additional performance when they move to a newer node. Similarly, LNC should get a lot of IPC increase too. How much increase is hard to say until they reveal the architecture, ES, etc.
Hulk
3,660
How much of a transistor density increase do you think we're talking about going from Intel 7 to the TMSC node?
Hulk
3,660
I created a little ARL calculator in Excel. Red font are my guesses, blue font is calculated from guesses, and black font is known.
Based on this input data I'm seeing ARL needing 20% Lion Cove IPC improvement and 22% Skymont IPC improvement to equal the 14900K in MT. Of course in ST this ARL model beats Raptor Cove easily.
If you have a prediction give me your numbers and I will run them. All I need is your Lion Cove/Skymont IPC improvement percent, and ST and MT frequencies for P cores, and frequency for E cores.
Reactions: Elfear
SiliconFly
1,925
1,284
A minimum of 2.5X (up to ~3+). Node density numbers are not very consistent as each node has different set of libraries and hence different densities. And each foundry quotes what they think is best for them (makes apples-to-apples comparison difficult). But general speaking, Intel 7 is around 100 MTr/mm2 I think and 20A is expected to be a lot denser than Intel 7.
I also remember reading a report which said that... even though densities keep increasing, the cost per transistor remains the same as newer nodes are more expensive. So, it's hard to say how much of an additional transistor budget LNC is gonna get due to cost concerns. But it better be a lot, otherwise it won't stand against competition.
Reactions: Hulk
SiliconFly
1,925
1,284
You haven't factored in additional ST performance due to removal of HT. I'm just taking a wild guess here... but I think it should be well above 10%.
Additional transistor budget should bring in at least 5% or more.
LNC architectural improvements should be at least double digits hopefully, which should be at least 10% or more.
Just wild guesses, but shouldn't be too off from the final product I think.
Hulk
3,660
All architectural improvements are "built in" to the ST performance IPC improvement percentage.
So what are you thinking ST improvement from Raptor Cove to Lion Cove? I am estimating 20%. Are you thinking 30%? We have not seen the likes of that type of improvement since P4 to Conroe. I'm not saying it's not possible, just wondering where you put the number?
At the end of the day all iso-frequency improvements come primarily from architectural improvements, especially when the memory subsystem remains the same between generations or the new generation doesn't leverage some new instruction(s) only used for some specific software.
Lion Cove and Skymont vs. Raptor Cove and Gracemont at iso-frequency in CB R23, how much improvement? This is really what it comes down to. We can estimate release clocks pretty well.
You are also right when it comes to transitioning the HT structures to improve ST performance. I think much of that will go into better OoO logic and cache structures.
AMDK11
456
373
Following the lead of SunnyCove and GoldenCove, the expansion of LionCove logic is at least 30-40%. I don't expect any smaller expansion. Of course, the more the better.
17,962
Imagine Lisa blowing away the crowd with pre-shipping silicon benchmarks of Zen 5 and then Pat follows that up with...gaming chips with AI!!!!
Yeah, that's just what the world needs, Pat.
SiliconFly
1,925
1,284
I'm too expecting at least around ~20% ST gains (+/- 5%). But then again, Intel being Intel, we may end up with nothing due to "various" reasons. Hoping they reveal something good sooner instead of constantly disappointing everyone.
Hulk
3,660
So are you hoping for something like this?
AMDK11
456
373
I think that looking at the average of the IPC growth curve of SunnyCove +18% and GoldenCove +19%, LionCove +20% is at least a 30-40% expansion of the core logic. If the expansion is larger than before, for example 40-50+% more, the average of the IPC curve will be higher. Anything less than 18-20% IPC increase will be a failure due to the fact that LionCove is not for one generation, but at least 2.
17,962
Has Intel stated that as a fact? I thought ARL would be followed up by Panther Lake, not a refresh of ARL.
AMDK11
456
373
Don't believe that the second generation after ArrowLake will be anything other than something like RaptorLake compared to AlderLake, i.e. GoldenCove with L2 2MB instead of 1.25MB. Intel doesn't have to confirm anything here because these are historical facts. If they provide an improved microarchitecture or a completely new one compared to LionCove, it will be a very big surprise.
I sincerely doubt that the second generation after ArrowLake will not be something like RaptorLake with GoldenCove L2 2MB instead of 1.25MB and more cores due to the design time that takes a lot of time.
If the ArrowLake refresh from PantherLake is new Cove cores, the changes in LionCove are smaller than in SunnyCove and GoldenCove. This is my current position on this topic.
SiliconFly
1,925
1,284
Actually, LNC spans generations.
And Panther Lake is a low-power SoC like Lunar Lake. A niche low volume product for a small market. Mainstream cpu is still gonna be ARL Refresh.
A lot rides on LNC. Shows Intel has a lot of confidence in LNC. Thats one of the key reasons ARL is gonna be a decent product I think.
