Page 116 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
922
840
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
SiliconFly
1,924
1,284
Anyone remembers this MLID "leak"?
We are being teased with 15-21% increases in IPC performance with the new Redwood Cove architecture over the Raptor Cove architecture, but with MLID apologizing for the huge range (15-21%) but I think that's fine."
No biggie, MLID missed it will be 0-1% , just a 100% failed prediction. I posted this here just to show how this guy either :
1) has no real sources
2) is making it all up for clicks and
3) has multiple "sources" who are actually trolls and who feed him BS info all the time
Very true. He's a dumbass.
Mopetar
8,517
7,777
  • They expect MTL iGPU to be the best performing iGPU in the market.
That's certainly an interesting claim and even if remotely true means Intel has seen some massive gains in their GPU technology.
Here's a few charts from AT iGPU tests of Raptor Lake:
There are some games where they're comparable, or even ahead, but others where they just get smoked so hard it's difficult to believe they could accomplish that
Even still, I want to believe it's loss just so they can shake up the GPU market even more with that technology. The GPU market needs a good shaking.
SiliconFly
1,924
1,284
He receive some noise but it look like he has trouble making the difference between IPC, frequency, better perf/watt that allow MT frequencies uplifts and so on, otherwise his 20% number is not far from other leaks, he s just unable to point to what parameter it is exactly related.
He once mentioned that he isn't an engineer and doesn't understand technical stuff. And based on his silly MTL predictions & ridiculous ARL projections, it's clear he doesn't understand a thing about foundry node characteristics. With that level of ignorance, he shouldn't be making bold predictions without proper understanding. It's just wrong.
Hulk
3,877
It's pure entertainment.
Reactions: Tlh97 and Elfear
Abwx
11,940
4,916
The games where they are comparable are those where CPU troughput matter, the others are GPU bound...
SiliconFly
1,924
1,284
Intel themselves claim that the gains maybe be up to 2X. But we need to take it with a grain of salt, as the game performance is not only dependent on gpu, but also cpu, memory, bandwidth, etc. They may be talking about best case scenarios.
trivik12
351
318
MJ is saying MTL desktop in 2024.
Also confirmed by MTL design head. 1st time design was more complex but going forward they can scale it for all power envelopes.
PCMAG: Given that all the discussions have been about laptops and mobile, is there anything intrinsic that Meteor Lake might mean for future desktop designs as distinct from mobile?
WILSON: Good question, good question. That's top of mind for a lot of people. I'll just say up front, this architecture will scale top to bottom in our client segment. Desktop all the way down to mobile. With Meteor Lake, we're launching mobile first. And that largely has to do with, if you think back to the keynote that I gave, the four key design principles around which we design the product, those really go toward the mobile segments first. Our most power efficient SoC we ever built...we want that in mobile. That 2x integrated graphics capabilitybringing discrete into an integrated form factor—that goes to mobile. AI applies to both equally. I would say, but because of the value proposition of the product, what we were trying to build, we targeted mobile first. But you will see this architecture scale top to bottom—up to desktop, as well.
Mopetar
8,517
7,777
I just pulled out a few of the different AT results just to give people a picture of how far they have to go in some cases.
2X is rather big jump. Have they given any indication of how they intend to get there? It's certainly possible to do just be throwing more resources at the problem, but that's where the bandwidth, etc. limits start to rear their head.
I was mostly hoping that they'd made some major improvements in their GPU tech, because that will mean their next set of GPUs should also see similar gains even without adding more cores.
mikk
4,319
2,400
I wouldn't say no sources, he definitely has there is no doubt. I can see this from the slides he is sharing sometimes and some infos with the code names, features, or even specs are just right. He was right with his 288 cores Sierra Forest forecast when everyone expected 144 cores. He is mixing real infos with false infos. His MTL IPC forecast was unrealistic from the beginning, it was crazy. Redwood Cove in Granite Rapids seems to differ with an enhanced uarch including improved branch predictor etc., it's like Redwood Cove+, exactly what MLID said. He said it comes with Redwood+ architecture on Intel 3 which gets 5-10% more IPC. I guess this is what Gelsinger meant when he said they enhanced Granite Rapids with new process and enhanced architecture: https://forums.anandtech.com/thread...-rapids-thread.2509080/page-614#post-40717471
mikk
4,319
2,400
Are you aware that the desktop chips only features 32 EUs compared to the mobile chips with 96 EUs? Also AMD didn't release a new desktop lineup yet with RDNA graphics expect for the 2CU version in Ryzen 7000 which is even slower than Intels GT1 Xe LP. It matters much more for mobile.
On paper Xe LPG is twice as fast as Xe LP due to a much higher clock speed and 33% more shader cores.
Khato
1,334
407
You can already compare the current Iris Xe against the Arc A370M to see how feasible a 2x performance increase is. The 112GB/s of the A370M isn't that far off the 120GB/s of shared bandwidth that the MTL pictured with on-package lpddr5x would have available.
Geddagod
1,621
1,667
Yes. Unfortunately, other than stuff that literally can not be misinterpreted wrong- like codenames- he gets nearly everything else wrong. Sigh
You forgot the part where in a later video he backtracks and says the 288 core version got canned to focus on the 144 core version.
No it doesn't. Intel outright said that GNR uses redwood cove, not redwood cove+. Also MLID thought RWC+ had, 12-21% IPC over RPC (false). He maintained this even after he brought down his IPC estimates for the original RWC.
mikk
4,319
2,400
It uses Redwood Cove, whether or not they officially call it Redwood Cove+ is not the point. The point is they are gonna use an updated/enhanced Redwood Cove over the Redwood Cove in Meteor Lake. Just compare the changes in Granite Rapids with Meteor Lake. It's enhanced in Granite Rapids whereas in Meteor Lake basically nothing, no IPC improvements in the core. Not even the usual improved branch predictor.
Gelsinger himself said they are using a major new core with 10 plus percent in the core. Redwood Cove in Meteor Lake certainly isn't major. I believe they planned with Intel 4 and Redwood Cove from Meteor Lake and later switched to Intel 3 and an enhanced Redwood Cove.
We did change the timing of Granite Rapids, and we had a big internal debate show on should we even keep the Granite Rapids name because it was the same platform, but it was a new core on a new process. So to some degree, it was a very different product. But some said, hey, you delayed Granite Rapids. Hey, I say I enhance Granite Rapids, with a much higher performance product, a much -- 18% process, a major new core, that's 10-plus percent in the core. So a much better product and aligned to the customers' timing.
Geddagod
1,621
1,667
No they won't. Other than perhaps the usual server upgrades (AMX, etc etc)
It definitely is the point, esp considering the claim was 12-21% increase in ipc lol
RWC in GNR is not going to have any IPC improvements over the RWC in MTL other than the usual server upgrades a core has. Also, prob the biggest change in RWC over Golden Cove was the change in L1I... which is seen in both diagrams.
Just because it's not listed out in the slide doesn't mean it won't be there. I expect the full list of changes to be provided at MTL launch.
Ye, I think the consensus on what happened there is that they thought they would be able to cram in LNC into GNR, but wasn't able to get it done. At least that's what Exist50 thinks (and what I've been speculating about since GNR was switched to Intel 3).
Either that, or that 10% plus in the core was in reference to the total perf/watt uplift as a result of the "major new core" and the better process for Intel 4 GNR vs Intel 3 GNR.
Either way though, if you think the most important claim of my original paragraph was that MLID is wrong because he called RWC in GNR "RWC+" rather than just "RWC", you must not have read literally the rest of my comment lol. And if you did, and do seriously believe RWC in GNR is going to have a 12-21% IPC uplift over RWC in MTL, then idk what to tell you... ig you're just way more optimistic for Intel then me lol.
(P.S. check out my MLID Intel leak tracker to find out just how bad MLID is at leaking info :)
mikk
4,319
2,400
Ok you have to prove this, can you? You are just saying NO without a real argument or proof from your side.
Here again, you have to prove your claim. I have to remind you your track record isn't great either, remember your High-NA babble. It was so obvious or even confimed they won't use it for 18A and you still refused to believe it.
It isn't strange to you they call it enhanced in the Granite Rapids slide and didn't in the Meteor Lake slide? Enhanced with zero IPC improvements, this is realistic right? It isn't strange to you Gelsinger refers to an upgraded core with more performance and even considered a name change?
I don't think so. They upgraded the core and then downgraded it again, there is no sign this is what happened. In mid 2022 when Gelsinger talked about the upgraded core it wasn't realistic in hindsight to even consider a server variant of Lion Cove in 2024. And Lion Cove on Intel 3, I don't think so. We weren' aware there is an enhanced version of Redwood Cove and simply assumed it must be Lion Cove which shortly later turned out this wasn't the case. With the enhanced Redwood Cove it makes sense now.
Geddagod
1,621
1,667
It's pretty simple, really. Intel called the core in MTL redwood cove. They called the core in Granite Rapids... redwood cove. Anyone claiming there's going to be any large changes between the two cores has the burden of proof to say they are different.
Because Intel changed their plans, my record (which btw I'm not a leaker on insider, I have made that clear numerous times) is bad? The only difference between me and you is that you choose to believe MLID (who I have empirically proven is a pretty terrible leaker).
Oh ye, and it was such babble that people in the industry also were speculating about High NA and 18A? Quoting Ryan Smith (an author for Anandtech)
Given that the release date of ASML’s High-NA machines has not changed, however, that announcement from Intel left open some questions about how High-NA would fit into their 18A node.
Btw, Intel announcing that high NA won't be used for 18a means that their claim of High NA EUV in HVM by 2025 was also a lie lol
That's just a lie. They didn't confirm it until like 3 days ago.
They called the core in MTL "new". This is the most marketing speak diction battle ever ffs
Yes, because it's enhanced in different aspects - like efficiency. Oh, and I'm sure you could cherry pick some benches for RWC in both MTL and GNR to have higher IPC than GLC,.
Weird how that one piece of info is never mentioned again lol. You would think it would be a really neat piece of info to put up in Hotchips...
Launch would be ~2 years away. That's cutting it slightly close, but GNR should still be in the design phase at that point, not after tape in. It's unlikely, but not impossible. And we have seen Intel work on the core or "redefine" products before as they get delayed. But that's an arguement you might want to have with Exist50, though he might be harder to find now (or just DM him on reddit lol).
LNC on Intel 3 would be what is expected of Intel. RWC is ported GLC on a new node, LNC should be on Intel 3 as it's "mature Intel 4". It's Intel usual cadence (well what it should be anyway).
No one assumed that but me. And I made it clear plenty of times it was my ambitious speculation. Most people believed it to be RWC.
No, because Intel claims GNR uses RWC. Do you really believe a standard P-core IPC upgrade is going to keep the same name as it's predecessor? Imagine calling Sunny Cove "skylake +" or Golden Cove "sunny cove+". Oh, and actually scratch that, it's even worse, Intel doesn't even call it +.
And that's if the interpretation that Gelsinger was referring to 10%+ as IPC, and not just a general perf/watt improvement as a result of the better node and improved architecture- which would also make sense.
SiliconFly
1,924
1,284
Maybe I shouldn't ask. But, do we really have to argue about a leaker whose predictions are based on his limited understanding of tech?
Info leaks are fine (whether it's real or fake). Keeps it interesting. But discussing the predictions of a baboon who lacks basic technical knowledge? Oh man!
Reactions: Geddagod
SiliconFly
1,924
1,284
WILSON: ...That 2x integrated graphics capability...
And not just the design head, I've seen two other videos where Intel people make similar claims. But like i mentioned, we have to take it with a pinch of salt. I think what they really mean is, that the iGPU's processing power has doubled. But that doesn't mean it'll directly translate to double the frame rates due to other obvious limitations mentioned previously.
AMDK11
484
424
I am of the same opinion that the same RedwoodCove(x86) is in GraniteRapids and MeteorLake.The difference in the presentation is that in the case of GraniteRapids Intel announced changes in the microarchitecture, and in the case of MeteorLake only that it is a new P Core.I believe that since Intel calls RedwoodCove a new core, it means that it is a generational jump and I assume an IPC jump in the range of 8-15%.
I am sure that more details, including numbers, will be provided on or before December 14.
inf64
3,884
4,692
Is there a chance that GraniteRapids uses ArrowLake cores? It would make sense that this is where the 10+% IPC increase comes from, since MeteorLake obviously brings close to zero IPC versus current gen parts.
SiliconFly
1,924
1,284
Actually, there's more to it. If we compare the leaked benchmarks of Core Ultra 7 with the equivalent i7-13700H (both operating at similar clocks), there's a slight performance regression. Possibly due to the introduction of the NOC interconnect fabric. Or maybe because the MTL samples are all ES.
