- May 21, 2012
- 3
- 0
- 0
Hi,
I will upgrade from AMD to INTEL the difference in performance is overwhelming for the same cost...i5 3750 vs FX8150 both are about $200. I read the Pro & Con's for Sandy vs Ivy, I find it difficult to buy a 2nd Gen over a 3rd Gen for about the same cost. btw my AMD MoBo is dead.
Please help, I need memory, I did the research and I'm still confused, too many to choose from with too many variables. I'm not sure about this G.Skill DDR 2133 for this build, although the price is right. I would rather not have to change the timing in BIOS.
G.Skill Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL11D-8GBXL...$59.99 [free shipping]
15% off w/ promo code EMCNEHF42, ends 5/30 [$9 discount]
http://www.newegg.com/Product/Produc...82E16820231468
ASUS Z77 MoBo Memory Standard...DDR3 2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333
Approximate Purchase Date: Yesterday
Budget Range: $400 +/-
System Usage from Most to Least Important: Gaming, Diablo3 & World of Warcraft.
Parts Not Required: See below list of Old parts.
Preferred Website for Parts: www.newegg.com
Country: Arizona USA
Parts Preferences: Open to Suggestions.
Overclocking: No
SLI or Crossfire: No
Additional Comments: I need Memory 8Gbs should do.
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K...$239.99 [free shipping]
$15 promotional gift card w/ purchase, ends 6/4
$20 MIR + $20 Combo w/MoBo
http://www.newegg.com/Product/Produc...82E16819116504
ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS...$149.99 [shipping $7.59]
$20 MIR
http://www.newegg.com/Product/Produc...82E16813131837
$75.00 Total Discounts for CPU/MoBo combo...not including
Memory
http://www.newegg.com/Product/ComboD...t=Combo.908895
Thank you in advance for the Help.
Overclocking: No
$20 MIR
Memory
My 3 year old Build:
CASE: Antec 900
CPU: AMD Phenom II X2 550 BE Callisto 3.1GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Processor - [running 4 cores OC'd 3.3 ghz]
MoBo: GIGABYTE GA-MA790XT-UD4P AM3 DDR3 AMD 790X ATX AMD Motherboard - Retail Support AM3 Socket Phenom II DDR3
Mem: OCZ OCZ3P13334GK 4gb kit (2gb x 2) 1333mhz 7-7-7-20 240-pin ddr3 dimm w/heat spreader
VC: EVGA SuperClocked 01G-P3-1461-KR GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI
PSU: OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply - Retail
HD: Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" - OEM
DVDROM: Sony Optiarc Black 24X 2MB Cache SATA DVD/CD Rewritable Drive - OEM
NIC Card: D-Link DGE-530T 10/ 100/ 1000Mbps PCI Gigabit Desktop Adapter 1 x RJ45
Router: D-Link DIR-655 802.11b/g/n Xtreme N Gigabit Wireless Broadband Router up to 300Mbps/ USB port x1/ Intelligent QoS Technology for Gaming
MONITOR: Samsung 22" w/TV tuner
OS: Windows 7 Premium 64bit
