Intel HD 3000 i5 2500K Display problem
Rast
Hello,
I would like to run my i5 2500k PC on igpu ( HD 3000). but everytime i want to boot, it crashes. then I put my HD 5770 inside it works fine. and boots without a hiccup.so when i boot with the intel HD3000 i can reach the bios,change settings. but when it try to boot windows it automaticly reboot. I never see that windows logo screen.
everything is on stock settings.I have plugged a VGA cable.
my rig: Gigabyte z68x-UD3H-B3 mobo, 8 gb ripsaw ram, samsung 120gb ssd OCZ 500 watt PSU.
someone knows this problem?
Thanks in advance
The solution is to NOT use the integrated GPU and use the 5770 as it works well and blows the doors off the pathetic 3000. I have a i5 2500K also and use 2 GTX 460 1GB.
Which do you have set as primary in the bios?
I use my onboard GPU to power a 3rd display and it works fine for that purpose, but I did find that the onboard doesn't function properly unless it is set as primary in the bios.
Did you have the onboard HD 3000 graphics enabled at first when you installed Windows the first time?
If not, try enabling the HD 3000 as the Primary like GotNoRice above says, but also keep the Radeon HD 5770 installed in one of the x4 or x8 PCI-E slots.
Then see if you can get Windows to detect both cards at the same time before removing whichever one you don't want.
I need the 5770 for my other pc. i want to use the HD 3000 for my silened pc.
I just checked on device manager, and can't see my HD3000(under Display adapters, only see 5770)
so what now?
Go into the UEFI BIOS of your computer and enable the onboard video graphics without setting it to be the primary display. Set that to be the PCI-E slot your Radeon HD 5770.
Then, when you finally get the HD 3000 graphics adapter to appear in the device manager and have loaded appropriate drivers for it, you can set it to be the primary display back in your UEFI BIOS.
Lastly, you can remove the HD 5770 and put it in your other machine.
Thanks guys, I tried everything but still it wont boot. everythime it tries to boot windows I go in rebootloop. maybe the HD3000 chip is broken inside the 2500K ?
