Intel Haswell presented at IDF - Feature overclock like LGA2011
Enigmoid
2,907
31
There s no such thing as "higher quality VRMs" or rather mosfets ,
they are always a compromise between switching speed and
high conductance.
Either they can withstand high currents and have low on resistance ,
but then they will have awfull parasistic capacitances that will command
high command currents to make them switch fast enough or they
will be fast but you ll have to give up on the conductance front.
In the first case dynamic losses will be higher than static ones
while it will be the contrary for the second type of device.
On overclocking dedicated MBs manufacturers will tend
to use slower but more rugged devices given the expected
usage , power dissipation being left out of the equation.
That is for the technical discussion.
Only religious people have no doubts...
Why is this in blank verse?
Ajay
16,094
8,114
SunRe
51
Unlocked parts supporting TXT will pose some threats to their E3 xeon line-up so.. I think it's not a typo or misinformation.
Mars999
304
Yeah I am going to be PISSED off if I can't get a 4770k with TSX along with the AVX2 is all I care about...
Abwx
11,896
4,878
This is a random result , for sure....
You seem to have no doubts that Haswell will fail.
The only thing that i v no doubt about is that technical
discussions are impossible with fanatics that see hate as
soon as their prefered brand is not praised all the way.
Thanks for the link..
