I connected four new and unformatted Seagate SATA HDDs to an Intel DP35DP motherboard. The hard drives are recognised in the BIOS and identified as ?non-RAID? volumes. This is fine so far because I do not want to use the RAID facility. The problem is that the SATA drive configuration options are then limited to RAID only. In addition the normal option to select ?legacy? or ?native? operation is not available. It insists on ?native? as a fixed answer.
If I try to select either the IDE or AHCI alternatives I want the previously populated SATA ports suddenly become ?not installed?. I suspect the denial of the "native/legacy" option is connected. Can anyone tell what I am doing wrong?
