You're surprised? I'm not. It's an Intel chip. certain people with agendas will use whatever angle to put it in a bad light IMO. They can't even use the 'you need a new chipset to run it' argument because it's backwards compatible with Z370, and trust me numerous posters have called my 8700K / Z370 combo a 'dead end platform with no upgrade path'.I don't get this
The 2700X already draws much more than 95W when properly loaded, we also know the numbers of 8700K (and its increase over 7700K). No big deal for current coolers.
Imo 9900K power will just match 2700X power and also match it when oced (like 2700X 4,2GHz vs 9900K 4.8-? GHz). Just with 25% higher performance- freq and IPC.
The picture will change as AMD releases their 7nm parts and imo match intel in absolute performance. Intel's 10nm fail is such a nice situation for AMD....
Logically, the only thing they can attack is the price and the power consumption or '95W TDP' which has suddenly become an issue even because well, its Intel. A 2700X draws in excess of 140W under full load and no one mentions it, but lo and behold if an Intel chips power usage manages to exceed TDP it's all doom and gloom, it will be stuck at 3.6GHz base clock, it's a gimmick etc etc
Make no mistake, if this was renamed an AMD R7 2900X with boost clocks at 4.7 - 5.0 AMD fans would be lauding it as the second coming...
