Integrated mobo Ethernet adapter vs PCI ethernet card?
Pott
103
I believe my mobo's adapter is on the fritz... after less than a week of me having built this PC.
Whenever a cable is plugged in, it just keeps on searching for it. I.e. it knows something's different from when nothing's plugged in, however it still tells me nothing's plugged in/it's not plugged in correctly (it is).
So I may need to get a PCI ethernet adapter, which are thankfully plentiful and cheap even here in Luxembourg. I'd disable the mobo one.
Motherboard issues aside, is there ever any advantage to running a seperate card from the integrated one?
Thanks!
Tsavo
2,645
37
Thanks!
There isn't an integrated solution made that can hold a candle to a NIC made by Intel. I use them in everything; zero problems and my network is both utterly reliable and fast.
JackMDS
29,544
421
Unless you are using the network in some type of complicated topology, or need to over task it.
There is No difference between the Onboard and stand alone PCI.
:cool:
Emulex
9,759
standalone pci nic's can be replaced when they fail. ever seen a machine blow up and take out everything on the switch? weird stuff happens when a power supply juices 220v to the on-board nic. not supposed to happen but does.
kinda like on-board modem (back in the days) versus internal - you know was easier to replace.
