- May 31, 2012
- 320
- 10
- 81
The Lian Li A71F has a removeable drive bay at the top back that I thought would work well for the H80. Upon looking at it, it does not have screw mounting holes and has a weird circular fan piece, and is meant for a PSU install. So I don't think I can install my H80 there... at least not easily :/
However, I could use the drive cage that came with it and leave it set to exhaust, and then use the H80 in the normal back fan port, and set it to intake? This would push air in and then the ONE exhaust would be in the back corner of the case pulling air out. My fear of setting the H80 radiator to exhaust is (1) it says it performs better set to intake and (2) most all of the hot air in the case would be being pushed out through it.
Thoughts on this? Here are pics of the case:
http://www.newegg.com/Product/Produc...pk=Lian%20A71F
(you can see the rear exhaust and top back removable HDD cage)
And the H80:
http://www.newegg.com/Product/Produc...=Corsair%20H80
And the H80:
