- Jul 7, 2000
- 1,980
- 0
- 76
My server has 8 hard drives. My current Chieftech has the fans on the front, between the drives and the case's front. One of the problems I have is that there is no such fan for the 5.25" drives, only for the 3.5" on the center and bottom. I added a "hard drive fan" but it is only enough for the the drive just behind it. My monitoring software shows that some drives are around 34 degrees C and some reach 45, and they are the same model and so unlikely that the reason is inherent heat but rather it is airflow.
I am modding a simple tower case, hoping to do better. The front isn't really suitable for fans, it has various hardware and plastic, and removing them would weaken the case.
I am considering putting any number of 90mm fans on the side panel, so they would blow in on the drives. There are mounting slots in the drive cages which I expect would let the air through. Also, some heat would be conducted to the drive cage and dissipated from there. I will put a 120mm exhaust in the roof of the case, which should be better than the current back-mounted exhausts.
The main heat source is the drives, the CPU is a PIII/933 Coppermineand the RAM is DDR 266.
Is this reasonable? I have more time than money to put into these things
