insulation removal
mizzou
9,734
54
anyone had blown in or very old insulation removed? my attic is a hot mess with areas having no insulation and insulated areas with old/dirty blown in and random batts laying around.
I really want a clean slate and new batts layed into the joists and get my eaves properly breathing again.
NutBucket
27,155
635
What about it? Either bag it yourself or pay the pros to vacuum it out. I know folks that have done both.
Reactions: mizzou
mizzou
9,734
54
wondering how expensive it is mainly, amd if it made any noticeable improvements
Greenman
22,339
6,486
You can rent the machine to suck it out. It's a dirty, sweaty, nasty job. Put blown in insulation back, it's a tighter job.
WilliamM2
2,998
884
Install baffles to get the eaves breathing again. I would just remove the batts, spread the old blown in around to loosen it up, and blow in fresh insulation. I installed baffles and blew in new insulation to 18" without removing the old 3- 4" that was already there (no batts). The difference is amazing.
The only time I have seen anyone remove the old insulation was if it was soiled with rodent feces, or had gotten wet in the past.
ivwshane
33,601
17,152
I removed old insulation myself for one part of my house and will be doing it again this spring. There may be a specific tool for the job but I used my leaf blower which has a vacuum option. I made a hose out of aluminum duct pipe for dryers. Its a real PITA! Get some quotes for the job and I'll tell you if its worth it.
The main issue I had was that it vaccumed into the leaf blower bag which was way too small for the job and was a PITA to empty out. I haven't figured out what I'm going to do this next time around.
