Originally posted by: Ferocious
Ok.
The confusion I have is if insulation is good for slowing down heat loss.....but the garage is unheated.....wouldn't it be a waste?
(Wouldn't a totally insulated house eventually reach outside temperature if the furnace stayed off (no one lived there.))
Originally posted by: dullard
I'm having difficulty understanding why you want to insulate the garage. Since the garage is unheated and attached, then you should already have a lot of insulation on the wall between the house and the garage. If you don't have insulation there, then insulate it as soon as possible since you are losing a ton of money out that wall. The other garage walls have very little reason to be insulated - you are right that in most cases it would be a waste. I can picture a few extreme cases (like if you open the door from your gargae to the house and leave it open) but for most uses I cannot picture any reason to insulate the whole garage. Can you provide us reasons why you are considering it?
Your first three are unusual circumstances (I've personally never seen a furnace or water heater in a garage - but that is probably since I come from an area where everyone has basements). And yes with unusual circumstances there are reasons. The average garage without insulation is 6°F hotter than outside. I don't know exactly how much an insulated garage will help. Probably the 20°F Maetryx posted is in unusual circumstances - I'd expect 10°F to 12°F to be typical. The improvement from 6°F is not worth the cost and effort for many people (and added property taxes if you get appraised). Otherwise all garages would be insulated.Originally posted by: Carapace
My need to work in the garage.
Insulation is not that expensive, it's easy and quick to install.
If your furnace is in the garage, it will operate more efficiently.
If your water heater is in the garage, it will operate more efficiently.
The luxury of getting in a warm car.
Not ruining some of the electronics I store out there.
