rh71
2700sf home with a Burnham ESC5 boiler and Techtanium 55-gal indirect water heater both installed 6 years ago and has been rock solid throughout (4 showers in a row with hot water) though I had this issue of little hot water once 4 years back also but self-corrected somehow. Important to note my baseboard heat does work / the boiler does come on. The issue: 1 kid would go to shower at like 8pm without anyone having used any hot water for a few hours prior, but the water is only mildly warm, even near max. Night before, the water is plenty hot and plentiful, same with that afternoon in another shower. Next night it's no good again at 7pm. I checked for any sign of leakage at the tank and there wasn't any.
Referring to the pics - thermostat on the boiler was set around 125F all along. I just raised it before taking the pics to see if anything will change. The boiler is on standby (code STA 1) as there's currently no call for heat (house temp 66F). I don't know if the gauge next to the boiler is supposed to read < 70F or just because it's off. The Grundfos circulator appears off and presumably only turns on when needed - seems infrequent though and according to the manual (https://us.grundfos.com/content/dam/GPU/Literature/TechnicalDocuments/ALPHA1-Installation & Operation Guide.pdf - page 14), the "light field" ever being off seems to be an issue. There are 5 zone valves (one being for the water tank)... something going on there?
https://i.imgur.com/sSGo5Ri.jpg
https://i.imgur.com/DPeR9Vi.jpg
https://i.imgur.com/a7xx92S.jpg
