Hey all. I've been a tad concerned about the stock fan settings for the EVGA 560 ti I have in my system. Under load (furmark), temperatures climb pretty quickly up to 90C and hover around there, but the fan rarely goes over 50% power even at these high temperatures. I had a fiddle with fan settings, and if I crank the fan up to 100% power the temperature's some 20C lower, so the problem doesn't seem to be case airflow. I set a fan profile using EVGA's precision software, and for the most part the fan rarely gets over 75% and 68C in real world use (Civ V, before it was hitting 88C in the same game), but it's noisy at that level. I know the GPU will withstand temperatures of up to 99C, so should I just switch back to the stock profile and stop worrying about it, or is it better to try and keep those temps a little bit lower?
Using an NZXT Guardian case with 1x front 120mm fan moving (by the other fans NZXT sells) 40CFM, 1x side 120mm, 1x rear 120mm and 1x XFX 140mm fan moving 60CFM. I'd been thinking of switching out the front and side fans for Antec Tricools moving 79CFM, would that likely help?
Thanks.
Thanks.
